    Device or hardware To Move Monitor In And Away
    5 Posts 4 Posters 1.8k Views 4 Watching
    • Joe WoodJ Offline
      Joe Wood
      I need some hardware that would enable me able to pull my monitor closer in to my face, so I don't need to lean forward so much which strains the old back! Google isn't helping as I don't know what this would be called. Something like a drawer slide?
      It would need to mount to the counter, or maybe to the wall which is 20" behind the monitor. Anyone have any suggestions, or at least what this is called??
      this is the setting.
      Joe Wood
      woodsshop.com/
      • tuna1957T Offline
        tuna1957
        Or maybe from these folks. Use to buy a lot from them in the days of paper catalogs.
        https://woodworker.com/cos-lcd-monitor-arm-grom-mnt-mssu-142-625.asp
        • Joe WoodJ Offline
          Joe Wood
          yeah Tuna that looks pretty good, and the arm extension works for me, good job finding that!
          Joe Wood
          woodsshop.com/
          • BoxB Online
            Many many options if you type 'monitor mount' into google.
              rodman100
              How about a monitor wall mount -single or dual, -they can be folded and placed against the wall & can swivel, 360° rotate, allowing you to adjust the angle as you want. With swiveling arms and freely adjusting height, you can ensure optimal viewing is easy to find the perfect spot. They usually have cable management ducting which prevents cables from being scattered and tangled, making your workspace more tidy and organized!
