    Old Stuff: SUbD Hornet with hair using Skatter 1.3 - 2016
    5 Posts 4 Posters 1.8k Views 4 Watching
    • duanekempD Offline
      duanekemp
      Dec 2016 using SU 2017 + Thea Render
      Back then... model build with new hair tests using Skatter 1.3, which had just come out.
      Insect built using SUbD... my first real project with SUbD.
      First four images are the remake of the head with shorter Skatter hair, all others are the first attempts.
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
      • Bryan KB Offline
        Wow! ๐Ÿ‘
        • alvisA Offline
          alvis
          ๐Ÿ˜ฎ
            Very nice, and an unusual subject ๐Ÿ‘ ๐Ÿ‘ I could go on forever about what is good about it, only thing is DOF would play a massive influence on these ultra small focal length macro shots. I would doubt if you would Get the whole wasp in focus never mind the any background at all. It should be a very blurred unreadable background ๐Ÿ˜‰ Great work though
              duanekemp
              Spot on Liam.
              And thanks for the compliment... much appreciated.
              I always intended to return to this for "renders" and never found the time. These were just test images to confirm the working Skatter. But, you are right.
              I did use this model only once, after this stage with some plants, that ended up with the DOF. But, it was more about the plants than the bugs. ๐Ÿ˜„
              https://sketchucation.com/forums/download/file.php?id=163888&mode=view/rokbox.jpg
              Topic here:
              https://sketchucation.com/forums/viewtopic.php?f=81&t=74018
              Duane Kemp
              Kemp Productions
              Gallery:
