    New plugin found at ferrari architecture
    50 Posts 20 Posters 49.0k Views 20 Watching
      You must select a welded closed curve...
      if that not works
      As it's an old plugin there is not adapted to the new versions!
      Load the 2017 Make linked to the previous post...
      It's working perfectly! πŸ˜„
      Else try the Soap Bubble Tensile Structure
      • E
        Einstein
        Yes, I know it's old. Just wanted to give it a chance hoping it would work.
        TIG, I use all the plugins you pointed, but Ferrari looks so cool that I'll use the old SketchUp just for it. I think it's worth it.
          Install the 2017 make! β˜€
          • majidM
            majid
            So there won't be any update?
            • E
              Einstein
              Rather not.
              But try contacting the developer, maybe they will help you. And let us know if you find something out:
              https://www.sergeferrari.com/
                Why you don't want Install the free 2017 Make ?
                Because I don't believe that plugin is follow-up by their creators.
                • E
                  Einstein
                  Ok, I installed SU Make 2017 and Ferrari. I get this error at SketchUp launch:
                  Error: C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in eval' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in require'
                  C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in require'
                  C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in load' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch.rb:17:in register_extension'
                  C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>'
                  Nothing happens when I select a welded outline and try to create a structure 😞
                    Seems I have FerrariSketchV1.1
                    From your error messages try these files
                    here mine in Windows 10 (it's not the "install" it's the files or folders where you have problems)
                    "C:\Users\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\FerrariSketch"
                    • Folder FerrariSketch
                    • FerrariSketch.rb
                    "C:\Program Files\SketchUp\SketchUp 2017\Tools\extensions.rb"
                    • extensions.rb
                    ferrari.zip
                    • E
                      Einstein
                      Oh my, it finally works!
                      I wish these old sketchup gems were a bit better documented. It's a wasted potential lying in these little scripts that most people are not even aware of, or they are not determined enough to dig and ask others for help to barely launch them.
                      Thank you, Pilou, a lot for your help!
                        You have some basic pdf here! πŸ˜‰ (and you are lucky in English )
                        doc_ferrarisketch.zip
                        • E
                          Einstein
                          I mean, yes, the instructions are good. The usage of this plugin is well documented.
                          What I wanted to say is, there are lots of valuable tools spread across forums and hidden in the darkness of the internet that could make work so much easier for many people, and there's no unique place to store them and keep them organized, with proper files kept in the way they are easy to find. You really have to dig deep sometimes, or just luckily stumble upon some gem (as I did yesterday). In this competition I find Blender and its addons better organized than SketchUp. But it's just my impressions and thoughts, and maybe I'm just polluting this thread πŸ˜›
                            You must take it as an adventure game! πŸ˜„
                              Ps I have said "Welded" : absolutly not necessary! 🀒
                              And can have any number of curves...
                              Just closed! πŸ˜‰
                              πŸ˜„
                              • F
                                Fperalta
                                Hello there,
                                If I read correctly you are using ferrari sketch on Sketchup 2017 due to compatibility issues.
                                Just wanted to point out, there's a modified version of V1.1 that works up to Sketchup 2021.
                                We also used an older version of Sketchup just to work on that extension and then move back to a newer version to complete our work, but we were having some issues and asked for help on the Sketchup forum and as a result Mcgordon provided a link he found of a rewritten extension that works in recent versions 😎 .
                                Here is the source link:
                                https://forums.sketchup.com/t/geometry-wont-paste-from-sketchup-8-into-sketchup-2020-pro/124860/8
                                Ps. The attached file is the same from the link, just converted to "rbz", for easier install.
                                FerrariSketch1.1v2015.rbz
                                • E
                                  Einstein
                                  Wow, that's absolutely awesome! 😎
                                  Thank you a hundred times!
                                  • 3 / 3
