Medeek Foundation Stopped Working
As the title suggests, Medeek Foundation stopped working for some reason. The only foundation that works is a rectangle.
I've uninstalled and reinstalled all Medeek plugins. I uninstalled Instant Architect which was my last and most recent plugin install. I also repaired SketchUp Pro 2021.
A polygon stem wall will create a foundation but it result in an exploded foundation in groups (stem wall and footing) with a line for rebar sitting on top of the wall.
When I construct either none of the construction dimensions show up. Just a dimension line and arrows.
I contacted Nathaniel already. Just looking for some input for now.
I also cleared all of my caches and temp files on my computer. Here's a ruby dump from just one line of creating a stem wall. Obvious errors here.
C:/Users/Asus P8P67 Deluxe/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:152: warning: constant ::Fixnum is deprecated Error: #<ArgumentError: Cannot convert argument to Geom::Point3d> c:/users/asus p8p67 deluxe/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/medeek_foundation_ext/medeek_stemwall_polyline_fnd.rbe:7661:inscreen_coords'
c:/users/asus p8p67 deluxe/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/medeek_foundation_ext/medeek_stemwall_polyline_fnd.rbe:7661:indraw' Error: #<ArgumentError: Cannot convert argument to Geom::Point3d> c:/users/asus p8p67 deluxe/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/medeek_foundation_ext/medeek_stemwall_polyline_fnd.rbe:7661:inscreen_coords'
c:/users/asus p8p67 deluxe/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/medeek_foundation_ext/medeek_stemwall_polyline_fnd.rbe:7661:indraw' -
Thanks to Nathaniel that helped my find the culprit that was staring at my face. It was offset.rb which was installed by windowizer4.rbz which I installed yesterday.
