    [Plugin] Material Browser - v1.1.2 - 15 Nov 2026
    53 Posts 11 Posters 40.1k Views 11 Watching
    • samuel_tS
      samuel_t
      Introducing Material Browser, a free plugin for SketchUp.
      Features
      • Search for SketchUp materials by name from:
        • Active model
        • Local collections
        • Poly Haven
      • Filter materials by type (Ceramic, Wood, etc).
      • Display larger materials thumbnails, up to 256px.
      • Select material of your choice in one click.
      • Support photoreal materials since SketchUp 2025.
      Screenshots
      Availability
      You can download it from the SketchUcation PluginStore.
      • samuel_tS
        samuel_t
        Material Browser plugin is going to evolve very soon. Stay tuned! πŸ˜‰
        • samuel_tS
          samuel_t
          1.0.2 version fixes and improves plugin zoom tool.
          Download latest Material Browser plugin from SketchUcation PluginStore.
          • samuel_tS
            samuel_t
            1.0.1 version allows you to:
            • Change thumbnails size.
            • Display names and sources.
            • Use a custom SKM folder.
            • cmeedC
              cmeed
              This looks very interesting! I've downloaded the Plugin, although its not working - it looks like i need those extra ruby script java 'things' - I've been attempting to keep a library of textures with names, i can use again and again in my Lumion workflow so this looks promising and i would love to try.
              The native material window is ok, like the component window is also but now i use 'Component finder' from flextools as my main window - its fantastic, will your Material Browser be similar?
              I have no idea what to do with extra additions needed to make this work - it would be better to keep it simple with the downloads (unless i'm missing something)
              Cheers
              • samuel_tS
                samuel_t
                Cheers
                Hello Chris.
                This plugin doesn't require Java. It does require Ruby but Ruby is already included in SketchUp πŸ˜‰
                Try to install this plugin following this video guide.
                If you don't succeed to install it, please provide me details: your operating system, your SketchUp version, what's not works...
                I will maybe inspire from FlexTools ComponentFinder plugin.
                Best regards.
                • samuel_tS
                  samuel_t
                  What's new in 1.0.3 version?
                  • One can filter materials by type (Brick, Wood, etc). Technically, a materials types dictionary is used and you can contribute to its development.
                  • One can choose to display only model materials.
                  • You don't need anymore to restart SketchUp after you've defined a custom SKM folder.
                  • When materials source are displayed: a click on Texture Haven logo opens texture source page in external Web browser. Download a normal map (for example) becomes easier.
                  • Plugin has been translated to french.
                  Download latest Material Browser plugin from the SketchUcation PluginStore.
                  • cmeedC
                    cmeed
                    I downloaded again - the latest update from the SketchUcation PluginStore and this time its worked. It definitely didn't come in the first time. I'm up and running now ! whoop whoop
                    So I've opened it for 30 second and i' already asking about features!!!
                    Could we have the ability to group materials together in folders and see these folders in material browser? this was a great help in flex tools
                    Material Question
                    on a side note - do you know why i can't have more than 1 material with the same settings but different names? so
                    Floor_Black (0,0,0)
                    Curtain_Black(0,0,0)
                    or how different these colours need to be to recognised as different from each other....
                    So,
                    Floor_Black (0,5,0)
                    • samuel_tS
                      samuel_t
                      I don't know yet if a feature of this kind will be implemented.
                      @cmeed said:
                      Material Question
                      Floor_Black (0,0,0)
                      So,
                      Floor_Black (0,5,0)
                      This looks like a SketchUp bug or limitation... You should create a topic about this issue.
                      • samuel_tS
                        samuel_t
                        What's new in 1.0.4 version?
                        • Texture Haven materials catalog has been extended to 198 entries.
                        • Downloaded textures are cached during 1 month... This accelerates re-import of concerned materials and saves bandwidth.
                        • samuel_tS
                          samuel_t
                          1.0.5 version brings a new materials source: CC0 Textures.
                          • E
                            EvilBoris
                            That's a really great plugin, I had some trouble getting it to work also: I had to disable a bunch of plugins for it to work, so there is a conflict somewhere.
                            For reference, here is the error I was getting
                            Error Loading File C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb
                            Error: #<TypeError: superclass mismatch for class StreamableStream>
                            C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:2:in <module:Zip>' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:1:in <top (required)>'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                            C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip.rb:30:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/utils.rb:27:in <top (required)>'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                            C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/model.rb:26:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/materials_observer.rb:24:in <top (required)>'
                            C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/app_observer.rb:24:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                            C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb:25:in <top (required)>'
                            • Z
                              ZoranKP
                              HI. I just installed this and only get errors when SU starts.
                              A lot of errors all to do with this: 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in `require'
                              I installed a few of your other plugins, all working fine.
                              Anything you can suggest to fix this?
                              Z
                              • Z
                                ZoranKP
                                Why are there no replies to posts here? The extension does not work as I posed above.
                                  masloprojekt
                                  Hello,
                                  Can You share a list of plugins you had to disable? I got the same errors. I would love to use this plugin, searching materials by name is so obvious it should be implemented in native tools of SketchUp, and this add on do so much more!
                                  Thank You.
                                  Maciej.
                                  my error log
                                  Error Loading File C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb
                                  C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:2:in <module:Zip>' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:1:in <top (required)>'
                                  C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip.rb:30:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                                  C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/utils.rb:27:in <top (required)>'
                                  C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/model.rb:26:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                                  C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/materials_observer.rb:24:in <top (required)>'
                                  C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/app_observer.rb:24:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                                  C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb:25:in <top (required)>'
                                  • samuel_tS
                                    samuel_t
                                    Hi everyone!
                                    Sorry, I wasn't subscribed to current topic. I don't have conflicts on my computer. Try to disable all other plugins and re-enable them one by one. Yes I know it's a tedious task but I see no other way...
                                    • samuel_tS
                                      samuel_t
                                      I just published 1.0.6 version. It should fix "TypeError: superclass mismatch for class StreamableStream" issue. Please upgrade if you have this issue. Then, tell me if it works.
                                      • samuel_tS
                                        samuel_t
                                        A SketchUp 2021 user reported that Material Browser v1.0.6 conflicts with SketchUcation ExtensionStore. You can't enable these plugins at same time because they use the same Zip library.
                                        I'm looking for a solution...
                                        • samuel_tS
                                          samuel_t
                                          1.0.7 version fixes "TypeError: superclass mismatch for class StreamableStream" issue. Material Browser plugin is now compatible with SketchUcation ExtensionStore plugin.
                                          • samuel_tS
                                            samuel_t
                                            1.0.8 version fixes "special chars in material name" issue. For example: a material named "<auto>1" doesn't cause anymore a missing thumbnail.
                                            • 1 / 3
