    [Plugin] MrHide (The Lost Toolbar) - v1.8a - 02 Apr 24
    25 Posts 9 Posters 14.1k Views 9 Watching
    • xayzerX
      xayzer
      @jclements said:
      Folks, I am working on Edge and Profile icons for Fredo this moment.
      @fredo6 said:
      NEW RELEASE: MrHide v1.4a - 03 May 20
      Requirement: LibFredo6 10.3b
      MrHide 1.4a adds a few features for toggling visibility of
      • Edge visibility
      • Edge profiles
      Holy crap, you guys actually did it! Thank you so, so much. This is a godsend as I'm constantly turning edges/profiles on/off in my workflow for certain projects, and I have a problem with my left arm where it's uncomfortable to move it around too much while working so I don't use many keyboard shortcuts and must rely on icons.
      Freelance Sketchup modeler, always looking for more work. Twitter: @Xayxer
      • xayzerX
        xayzer
        @jclements said:
        I have a similar problem with my left shoulder; an artificial shoulder that has seen its last days. Quite painful and disabilitating at times.
        Ah, man, I'm so sorry to hear that, JC. Hope there's a solution for that problem.
        Mine is far less serious than yours. My left elbow is a bit wonky from years of resting it on an uncomfortable surface while working at the computer, and if I have to lift it up too much to reach for any shortcuts that aren't in the general left ctrl area, the pain starts to build up so I use only the very basic shortcuts.
        Once again, thank you for your work on this plugin!
        • jujuJ
          juju
          This is one of those extensions you think to yourself:" Self, nah, this functionality is already there, just clutter." Then you remember who the author is and think to yourself: "Self, you extensions snorting hippie, let's try it out." Now it is one of those extensions that you're soooo thankful for, saving you time and effort from the get-go.
          • JClementsJ
            JClements
            ". . . I have a problem with my left arm where it's uncomfortable to move it around too much ..."
            Glad to hear the toolbar helps you.
            I have a similar problem with my left shoulder.
            • JClementsJ
              JClements
              Folks, I am working on Edge and Profile icons at this moment.
              • fredo6F
                NEW RELEASE: MrHide v1.5a - 25 May 20
                Requirements
                • LibFredo6: v10.5a
                MrHide 1.5a brings a correct state of toolbar icons for Mac
                Home Page of MrHide for information and Download.
                Main post of this MrHide thread.
                • B
                  bharralure
                  Bonjour Fredo
                  Jutilise à la fois SU 19 et SU 20, sur lesquels j'ai installé Mr Hyde v1.5a et LibFredo6 v10.9a.
                  Les vignettes que jaffichent dans la barre d'outils sont réduites à 6 pour SU 20, et 5 pour SU 19 (Affichage Objets Caché n'existant pas dans SU 19).
                  Mon problème est le suivant : après avoir paramétré la barre d'outils depuis le lanceur rapide dans chacune des versions, puis relancé est refermé les deux versions, lors de la prochaine ouverture d'un fichier, nouveau ou existant, et peu importe la version, je me retrouve avec l'affichage de la barre d'outils complète, ce qui entraîne une désorganisation totale de l'ensemble des autres barres d'outils par manque de place.
                  Le problème n'existe que sur la première version ouverte, la seconde conservant mes propres paramètres.
                  Existe-t-il un remède Docteur ?
                  D'avance merci pour une réponse.
                  • fredo6F
                    Il y a un remède. J'ai réussi à reproduire. C'est un effet de bord du fait que les Default Parameters sont communs à toutes les versions de Sketchup (pour rendre la migration à de nouvelles versions plus aisée).
                    Je ferai une correction.
                    • B
                      bharralure
                      Merci Fredo
                      • fredo6F
                        NEW RELEASE: MrHide v1.6a - 22 Nov 20
                        Requirements
                        • LibFredo6: v11.3a
                        MrHide 1.6a minor release for bug fixing in states
                        • fredo6F
                          NEW RELEASE: MrHide v1.7a - 23 Feb 23
                          Requirements
                          • LibFredo6: v11.3a
                          MrHide 1.7a is a major release fixing a bug related to Draw Back Edges
                            db11
                            Merci Fredo for a very useful toolbar.
                            • fredo6F
                              NEW RELEASE: MrHide v1.8a - 02 Apr 24
                              Requirements
                              • LibFredo6: v14.3b
                              MrHide 1.8a is a maintenance release for:
                              • Future compatibility
                              • 2 / 2
