    [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
    201 Posts 64 Posters 181.6k Views 65 Watching
      stpauljason
      Thanks Thomas,
      I updated Sketchup 2013 and the plugin has its own toolbar now.
      • H Offline
        Hammerhead64
        Chris this is such a good tool, I have spent years using a combination of the standard tools in SU to get elements perpendicular to a path. Thx for sharing.
        ....... Quicker models here I come.
        • gonashviliG Offline
          gonashvili
          Just wanna say that this plugin is them bananas. Super, SUPER useful.
          Cheers.
          • sicksickisckS Offline
            sicksickisck
            still does not work inside a component
            • cottyC Offline
              cotty
              What do you mean here? Do you have an example?
              my SketchUp gallery
                Yes. What do you mean? I just tried it and it works fine inside a component. I made a component of the Bezier curve, opened the component for editing and ran the tool. It put the face on the end where I clicked.
                • djohnson.nzD Offline
                  djohnson.nz
                  Thanks Chris, extremely useful time saver.
                  I did have trouble creating a circle in a group, it didn't seem to work but after closing the group I found the circles outside the group. I was able to remedy this by changing your "Perpendicular Circle" script to read entities=model.active_entities which I found was the only thing different from your Perpendicular Square script.
                  Thanks for all your great work...
                  nO fiKst ideas
                  • designerbursaD Offline
                    designerbursa
                    [highlight=#ffffbf:39kxqslm]still does not create circles of less than 30 mm[/highlight:39kxqslm]
                    I'm working in mm, 2540 is the default by default.
                    Changed by changing the r.b code
                    thanks for the plugin
                    my edit:
                      def activate
                        @ip = Sketchup::InputPoint.new
                        @iptemp = Sketchup::InputPoint.new
                        @displayed = false
                        @sp = []
                        @end_pos = []
                        @ctrlflag = 0
                        @group = nil
                        if @@ls.to_s == ""
                          @@ls = **100.mm**
                        Sketchup.set_status_text @@ls.to_l, SB_VCB_VALUE
                        Sketchup.vcb_label = "Face Width x Height"
                      thegoodguy
                      I just installed this on Sketchup 2016. It worked well and was super-useful when I had Sketchup 8, but is not working on 2016. There are no notes I can find saying which versions this plugin is compatible with. Am I missing something?
                      Thanks.
                        It works fine in SU2016 as well as every version up through SU2020.
                        You might try restarting SketchUp to make sure the plugin loads.
                        Are you sure it's not working? Is it possible the face it's creating is just so large its edges are outside the view of the camera?
                        • Z Offline
                          zaz1
                          I just discovered this extremely handy plugin. Thanks so much Chris. Plays very well with Curviloft for drawer pulls and other yet to be discovered objects. I have a couple of questions and please forgive me if these were answered earlier but there are 197 posts on this thread. I am using a MAC and that may be part of the problem with the issues I am seeing.
                          1. What key controls the rotation? I have tried up, down arrow, option, control but no success.
                          2. How to access the circle radius change in the VCB ?
                            The VCB only displays Face Width x Height. I can enter a value, say 2" and that will set the circle radius. The video shows a VCB display of circle radius which I cant seem to display.
                          3. Is a 1" radius circle the lower limit ? If I enter a value for a circle radius less then 1", it does not display the circle when I click on the line segment. Currentlly I use a 1" radius circle and change it to less than 1" later with entity info.
                            ParkKangSuck
                            Hello? I am using the Perpendicular Face Tools created by you. Recently, I would like to modify the content of the source code to add new features according to my needs. Your copyright notice will remain intact, and there will be no changes regarding the copyright. Can you give me permission to modify the source code?
                              ParkKangSuck
                              Hello? I am using the Perpendicular Face Tools created by you. Recently, I would like to modify the content of the source code to add new features according to my needs. Your copyright notice will remain intact, and there will be no changes regarding the copyright. Could you grant me permission to modify the source code? Thank you.
                                ParkKangSuck
                                • 11
                                • 9 / 11
