    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Namespace in Multiple .rb Files
    5 Posts 3 Posters 4.9k Views 3 Watching
      BryanHL
      I am creating an extension and it is time to split everything out into multiple files.
      I have in my main file...
      require 'sketchup'
      require_relative 'Model1'
      module MyNameSpace
        module MyModels
          def self.create_model1
            model1
          unless file_loaded?(__FILE__)
            # add menu items
            menu_Models = UI.menu('Extensions').add_submenu('My Models')
              menu_Model1.add_item('Model 1') {self.create_model1}
      and in the second file
      def model1
      After reading about namespaces I included the namespace and module names in the second file, as I had seen in other extensions.
      It was all working until a SketchUp restart and I got an
      "Error: #<NameError: undefined local variable or method model1 for MyNameSpace::MyModels:Module>"
      module MyNameSpace
        module MyModels
          def model1
      After tearing my hair out I removed the namespace and module references and after a SU restart it works again.
      What have I misunderstood about namespaces and module names? If it means anything I am not using classes at all.
      Also, is there a way to reset the Ruby interpreter so a SU restart is not required?
        module MyNameSpace
          module MyModels
            def self.model1()
        Should work ?
        Then any file using that module can call the method...
          BryanHL
          @tig said:
          module MyNameSpace
          >   module MyModels
          >     def self.model1()
          Should work ?
          Thanks TIG,
          that worked, although I thought I had tried that - maybe without a SU restart.
          On the SU forums Dan R also showed me extend self.
          • PixeroP Offline
            Pixero
            For what it's worth.
            If you temporarily comment out the line: unless file_loaded?(FILE) you can run the script again without restarting SU but you will get a new plugin menu entry for every time you run it.
              BryanHL
              I had been loading the script from the console, then created a menu entry to do just that (from your How to Debug thread), but naively assumed it would reload any required files. Added another menu entry for the file in question and all is good...
