    Scaling
    extensions
    7 Posts 3 Posters 5.3k Views 3 Watching
      mitchelladema
      Hello, I am using the Fredo Scaling tool for the first time. Sometimes it works like it should, but some times some parts are nog scaling with the rest, it stays as it is.
      I really hope someone can help me out.
      I will try to upload a video.
      Many thanks,
      Mitchell
        Depending if you press CTrl or not, if the base Plane is fixed or not...etc...
        Each Plugin of Fredo must have a little training because it's like a little program itself! πŸ˜‰
          mitchelladema
          Thank you for response. But I tried everything, but can't find how to handle it. My closet is build up with different components, and at the end I made them all together as 1 big component.Most parts are scaling, but a few parts don't do anything, just stay the size they are.
          As you can see is that the left and right vertical shelves are scaling, but the small part that I'm pointing at stays it's orriginal size.
            mitchelladema
            I really hope you can help me how to handle this, because it will save me lots of time if the scaling works as I want it to work.
            Many thanks in advance,
            Mitchell
            • pbacotP Offline
              I've had problems myself with Fredoscale and multiple nested components. Try posting in the thread for this plugin, to see if there is an answer. I never found one, I just stopped trying to use it on complex objects--or use it on smaller portions of the model at time.
                mitchelladema
                Thank you for your reply. That was not he answer I was hoping for 😞
                  Post you model skp for test! πŸ˜‰ Save as V6 for a more large audiance! πŸ˜„
                  https://i.postimg.cc/FzgQ2pTb/v6.jpg
