π Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
STL Question
I have an STL file I want to print but I want to have the background to be solid white. At the present time it has no background color. I've attached a pic of the file to see what I'm talking about. Any help with this would be appreciated. Thx
A little bit late answer and I'm not sure if I understood the question correctly. But make a square and lay the wings over it. Intersect & clean. A lot of work perhaps. Works if the bottom of the wings is flat enough.
Maybe by changing sketchUp model, you can get a white background directly?
