Graphics Resizing Question
can I open a photo that's 2,400 pixels wide and 180 DPI, and resize it changing only the DPI to 300, for printing?? I just did and it's now 4100 pixels wide?
I have a feeling though that you can't improve a photo file?
Yes you can but result can maybe not that you whish
There are special progs for that!
*6 is now the max ...even *8!
Some are shown in this video
A free one who is not
Max. file size for upload is 5 MB.
Supported file types: jpg, png, gif, bmp.
Max. dimension for input images: 4100 x 4100 (so you are inside!
Possible Ratio is depending of the Input Size Image (but don't dream
Frenchy I don't understand that program,
If I want an image to be 300 DPI, what are the zoom factor, target width, and target height I input?
300 DPI is normally Scale 1 / 1 in Print Paper
So make anything you want with an image (rezizing, color etc...) then put your 300 DPIIf your image change of size it's that you have make also a resizing not a only a change of resolution!
An image 640 * 400 at 72 DPI (Internet) or 96 DPI (screen) or 300 DPI (Print) >600 DPI (Luxuous Print
will always 640 * 400 pixels !DPI (Dot per Inch) is only Number of Points along a distance for Print works Paper !
A pixel is not a Point of Print! -
Thanks again Frenchy, I found one of those online programs that made it very easy.
