    Medeek Engineering
    46 Posts 4 Posters 11.3k Views 3 Watching
    • medeekM Offline
      medeek
      I was going to name the engineering module or plugin “Medeek Structural” however I’ve decided to change the name to “Medeek Engineering”.
      The plugin icon will now be:
      https://aws1.discourse-cdn.com/sketchup/original/3X/c/c/cc75956a7b322db9376e0a5e526f1d02fb6022f1.png
      https://aws1.discourse-cdn.com/sketchup/original/3X/b/6/b6083c334d2992b654648921003d8238d453d822.png
      The first toolbar I will add is the Beam Engineering Tools which will allow the user to add point loads, distributed loads and supports to beams drawn in the wall plugin:
      https://aws1.discourse-cdn.com/sketchup/original/3X/0/d/0df0644fc0ee815ff8674d2846f90fe0ca32450a.jpeg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        https://aws1.discourse-cdn.com/sketchup/original/3X/7/9/79936bf21f4819ac300b30c3bd0fd3a847e07642.jpeg
        design.medeek.com
        • medeekM Offline
          medeek
          This will be a separate extension that will be integrated with the other extensions in the mdkBIM bundle. It does not need to be installed with the mdkBIM bundle and is completely optional. However, it is not really a stand alone extension since it can only be used with geometry drawn by other Medeek extensions.
          After giving it some additional thought I think it would be good to decouple this extension to the extent that even if for example the Wall plugin is not installed the user could install the engineering extension and still apply loads/support and analyze a given beam. However they would be unable to modify the beam as drawn (ie. size, depth, length) unless the Wall plugin was installed.
          In the Account Manager its icon will be:
          https://aws1.discourse-cdn.com/sketchup/original/3X/7/3/73a2defbd24ed75ef98c49c034858612d2e58a7b.png
          design.medeek.com
          • medeekM Offline
            medeek
            With respect to who will use this module, I actually do think a lot of architects and designers would find use for it even if they are unable to “stamp” their design as “engineered”. There would be many situations where a designer would want to get a reasonably ballpark idea on how big a beam or header needs to be. Unless there are complex loading situations at play, assigning some basic loads and supports to a beam is usually not rocket science. However, as always it is garbage in, garbage out. Obviously the user needs to have some understanding of the correct site specific loads in order to get the correct answers.
            That being said, my primary audience for this plugin is residential structural engineers (like myself) who are wanting to quickly apply loads to a design and push out a report with minimal effort. I still have a long way to go with all of this but I am definitely opening a new can or worms with this one, let’s see where we can take it in the next few months.
            I think I am entering uncharted territory with this new development. To my knowledge there does not exist a comprehensive software that combines architectural design with engineering, that is my goal with integrating this new engineering module/extension with the mdkBIM suite.
            design.medeek.com
            • medeekM Offline
              medeek
              When you click on the “Draw Load/Support” icon of the toolbar you will be presented with this matrix menu:
              https://aws1.discourse-cdn.com/sketchup/original/3X/a/a/aa4eaf5aaabd422dc1cd3fd23d0534493037259b.jpeg
              design.medeek.com
              • medeekM Offline
                medeek
                Still working on how best to graphically represent the various loads and supports but this a bit of a preview of how it will go:
                https://aws1.discourse-cdn.com/sketchup/original/3X/6/1/61c9f0316ba58464abefb7fd6def11fdc0475871.gif
                design.medeek.com
                • medeekM Offline
                  medeek
                  The loads and supports will be on the Eng layer, annotations will be on Eng2 and warning graphics will be on Eng3.
                  Here is an example of some point loads applied to a timber beam, now I just need to setup annotations:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/e/8/e8e773954addac2a41432dca16c60e8968737e4b.jpeg
                  The different color arrowheads indicate one of the six load types (Dead, Live Floor, Live Roof, Wind, Snow, Seismic). The colors assigned to each load type will be able to be customized in the global settings. The size of the arrowheads will also be customizeable.
                  Regenerating the beam geometry will not regen the loads, there will be separate context menu item (right click the beam) to regen the engineering loads/supports.
                  design.medeek.com
                    All these marvelous things will be also in metric system ?
                    • medeekM Offline
                      medeek
                      An example of point loads with Load Labels and Magnitudes turned on:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/8/b/8bd9ddb82f8093154fd942b0b7e25a2603b5f697.jpeg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        An example of some distributed and point loads applied to a steel (W) beam:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/2/2/22e683dccd8e4981ffd08354ef06bb3e23366062.jpeg
                        I could also do something like this for the distributed load representations, thoughts?
                        https://aws1.discourse-cdn.com/sketchup/original/3X/1/6/160711e62876d4de79b5bfecd7f48eb9ea601dce.jpeg
                        Now I just need to add the supports and we are done with the engineering geometry.
                        After that I need to figure out the finite element analysis (matrix analysis) engine that will be used to calculate the shear, moments and deflections of the beam (single or multi-span). Since the number of loads and supports is potentially unlimited there is no one classical equation that will solve this problem:
                        https://www.awc.org/pdf/codes-standards/publications/design-aids/AWC-DA6-BeamFormulas-0710.pdf
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          The last matrix analysis engine I wrote was for the truss calculator, its been a while. The good news is that I have my textbook on how to do it and it turns out that the beam analysis problem is really only a one dimensional problem, much less complicated than a two or three dimensional problem. This is going to be fun, just so you guys no I'm on summer vacation right now so let me have some fun with a bit of engineering.
                          This is my reference and favorite text on the subject matter:
                          https://www.amazon.com/Structural-Analysis-7th-Russell-Hibbeler/dp/0136020607
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            An example of a beam with loads and supports:
                            https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/e/1e538dc6d640302ea2044c2c010f5d0a85f2ddf6_2_690x429.jpeg
                            Clicking the control key allow the user to insert supports by their center and then bearing length.
                            View model here:
                            https://3dwarehouse.sketchup.com/model/9e576bc8-88cd-4a71-9b47-3c0298b6e823/Beam-Engineering-3
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Insertion of a support:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/5/5/55dad3ea463a71671bbe134637ee1b86aee4ad8c.gif
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                When you assign a support with blocking (lateral bracing) then it will be drawn with a dashed line (both sides of beam) as shown to indicate that bracing is being provided at that location:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/a/2/a2b1ebbf16deb3e787e9b5b1f198ebd74640cc7a.jpeg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Editing a support:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/e/7/e75bf65e90bdb256c56bd1c3fec28fd37e55e9cc.jpeg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    The beam engineering geometry features are now complete. You can now add, move, delete or modify an unlimited number of supports, distributed loads and point loads. If the beam itself is modified there is also a function to regenerate all of the engineering geometry to properly match the updated beam width and depth.
                                    The next step will be to work on the actual engineering engine (FEA) and add in additional engineering (global) parameters. Some of these parameters will be things like deflection limits etc...
                                    design.medeek.com
                                      dtrarch
                                      Great stuff Medeek 👍 👍 👍
                                      Really super study script to understand loads and reactions.
                                      How about an FEA just for fun.???
                                      Thanks for all your good work
                                      dtr Architect
                                      • medeekM Offline
                                        medeek
                                        Moving a distributed load:
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/a/3/a351dc7a76b462ff91f19f84dacd2ab1e704cc0d.gif
                                        It may be more intuitive to select the distribute load and then select whether to move the start or end point, rather than just moving it by its center point. Granted, one can modify the start and end locations within the edit menu.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          The updated toolbar with the “Engineer Beam” icon added.
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/c/e/ce713e1052b214c11658b72343ec1f9b6a2b3c78.jpeg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 0.8.0 - 03.14.2021
                                            • Created the Medeek Engineering Plugin, utilizing SketchUp's Ruby API (BETA release).
                                            I haven't paid much attention to this plugin for about 8 months as I have been so busy updating all of the other plugins (Wall, Truss, Foundation and Electrical). When I get some more time I will get back to work on the matrix analysis engine that is required for the calculation module. For now you should be able to add loads and supports to beams created with the beam module of the Medeek Wall plugin.
                                            The plugin is very much in BETA right now, however I wanted to at least get it out so people can start playing with the load and support tools and give me any feedback they might have.
                                            The BETA/Trial version of the plugin can be downloaded here:
                                            http://design.medeek.com/resources/medeekengineeringplugin.pl
                                            Note, that you cannot purchase this plugin yet. I will not enable purchasing until I have completed the calculation module and brought it out of BETA status.
                                            design.medeek.com
                                            • 1 / 3
