    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] GKWare Cabinet Maker
    625 Posts 67 Posters 439.8k Views 68 Watching
      Garry K
      Billy - Thanks for your kind words.
      Sliding doors is on my radar.
      New versions are now available on my website
      CabMaker Version 6.0.150 – Feb 15, 2020
      1. Door report now has 2 new columns - Part Type and Material.
      2. Fixed Stretcher in Face Frame construction.
      3. Added Alt-D to give user the ability to delete templates - one at a time.
      4. Added Expression Evaluator.
      5. Cleaning up folders – simplifying.
      6. Scene generation Plan wasn't always working. Fixed.
      CutMaster Version 6.0.1.94 - Feb 15, 2020
      1. Angled Tops and Bottoms - no backs - Fixed
      2. Import mapping modified in database
      3. Cleaned up 4 tables in database - no more fixed length characters
      4. Layout listing now adjusts sizing for extra room for small parts.
      5. DXF Reports now use adjusted size but without parts padding.
      6. Angled fixed shelves were not angled. Fixed.
        Garry K
        Bill - Sliding doors are on my radar.
        Currently working on CabMaker 6.0.151
        1. Multi row door panels was flipped in Mid and Tall cabinets. Fixed.
        2. Fixed rounding error with integrated kicks and notching
        3. Renaming of Cabinet templates and Rule templates no longer deleting old name
        4. Now working on Project level materials and rules
        Todo:
        1. Finish Project level materials and rules
        2. Simplify adding textures
        3. c-channel and j-channel
        4. sliding doors
        5. merging - closets
        6. merging - face frames
          Garry K
          The most current version of CabMaker is now available on my website.
          Version 6.0.151 – Feb 29, 2020
          2. Fixed rounding error with integrated kicks and notching.
          3. Renaming of Cabinet templates and Rule templates no longer deleting old name.
          4. Added PROJECT level for resources, Rules, Materials, Doors and Drawer Systems.
          5. Alt-S now works for all resouces.
          6. Dropped Alt-R, no need for rename since we have save as and delete.
          7. PROJECT tab now defaults to all tabs locked.
          8. Added Context help for resources.
            Garry K
            Working on 6.0.152
            Handless cabinets
            • H Offline
              henco
              I installed CabMaker on a new computer, but I keep on getting Web Service Error -25... How do I remove the license from the old PC and get it to work on the new one?
                Garry K
                You need to email me requesting a reset. You must provide me with your userid.
                  Garry K
                  CabMaker 6.0.152 is now available from my website.
                  1. Added Handless Cabinet support.
                  2. Modified Parts reports to include new handless information.
                  3. Locks for new project are now in Edit Config.
                  4. CabMaker kept adding same material to project - fixed.
                  I am now working on CutMaster to support the notching for handless cabinets.
                    Garry K
                    CabMaker 6.0.155 is now available from my website.
                    Version 6.0.155 – Apr 20, 2020
                    1. Cabinet merging now works better for face frame cabinets.
                    Version 6.0.154 – Apr 11, 2020
                    2. Standard Drawer backs not positioned correctly when back is sitting on bottom.
                    3. Door and Drawer tabs not updating when changing templates. Fixed
                    4. Now adding a message if reports have nothing to do - cabinet quantity = 0.
                    Version 6.0.153 – Mar 31, 2020
                    1. Edit Config now defaults to false for 'Locks on new project'.
                      Garry K
                      CabMaker 6.0.157 and Cutmaster 6.0.1.99 are now available from my website.
                      CabMaker
                      Version 6.0.157 – Jun 19, 2020
                      1. Modified Merging for closets. Optionally the Left side for the right cabinet is the only panel that is changed. Backs, Tops, Bottoms, hangers are not modified.
                        Version 6.0.156 – Jun 7, 2020
                      2. Modified Leg placement for Return Cabinets and Angled Ends.
                      3. Modified CutMaster report for Side Dado.
                      CutMaster
                      Version 6.0.1.99 - Jun 19, 2020
                      1. Fixed Parts report when using fractions such as 16 29/64ā€. Had to increase the size of the Width and Length columns.
                      2. Fixed merged panels for DXF. The left panel of the right merged cabinet now goes into a folder named ā€œBackFaceā€.
                      3. Modified Blind Mortise and Tenon for CNC. More control for handling tenon notches.
                        Version 6.0.1.98 - Jun 7, 2020
                      4. Added Flip Tops, Flip Fixed and Flip Bottoms to General Options.
                      5. Removed ā€œDrill From Bottomā€
                      6. Completed Angled Ends for Blind Dado.
                      7. Added Single line tenon cuts instead of pockets.
                      8. Modified Leg positions for Return cabinets and Angled Ends.
                      9. Added pocket option for Construction holes and Dowels. This supports Festool Domino and Lamelo.
                        Version 6.0.1.97 - May 11, 2020
                      10. Configuration settings now has checkboxes to turn on / off DXF sections.
                      11. You can now have any width of blind tenon (stop tenon).
                      12. You can now set full dado width to 0 to get single line instead of a pocket.
                      13. Bottoms, Tops, Stretchers, Fixed Shelves and rails can now have single line choice instead of pocket.
                      14. For Blind Dado's added 4 new parameters, Depth Adjustment, Up Down Adjustment, Tenon Width Adjustment and Reverse Bottoms.
                      15. Reverse bottoms is intended to be used with integrated kicks.
                      16. Added Pocket Length to Construction Holes to support Festool Domino and Lamello.
                      17. Added Start Line indicator for CNC view.
                        Garry K
                        Now you have more control over Blind mortise and tenons.
                        Here are 2 examples with and without integrated kicks.
                          Garry K
                          A new version of CabMaker is now available
                          Version 6.0.158 – Jul 1, 2020
                          1. Modified Sink cabinet. You can now have side by side drawer fronts without a stretcher.
                          A new versin of CutMaster is now available.
                          Version 6.0.1.101 Jun 30, 2020
                          1. Fixed drawer bottoms for single line routing directionality.
                          2. Added pocket screws for drawer bottoms.
                          3. Added optional X / Y offsets for routed label positioning.
                            LusaMx
                            Just installed the latest version. But once I try to run for first time the login dialogbox appears and ask for "hardware". If i use the ID and password registered at website but "hardware" field blamk. Sketchup freezes and the only way to starover is ctl+alt+del and kill the process.
                            Why?
                            Regards
                              Garry K
                              I am currently helping him via email.
                              • utilerU Offline
                                utiler
                                Good morning Garry, is there a way to change the door arc radius? I note that its set to 120 degrees as standard but I'd like to set it to 85-90 degrees.
                                Can't seem to find it anywhere in the manual.
                                Cheers,
                                Just Curious...
                                  Garry K
                                  Try this
                                  • utilerU Offline
                                    utiler
                                    Seriously, I need glasses... Thank you Garry. 😳
                                    Just Curious...
                                      marcinek12
                                      I got problem with plugin gkware cabinet maker v6
                                      Window come up with Registration
                                      User id i got it
                                      What password i need to tape in
                                      I need to registered somwhere?
                                      Thank you
                                        Garry K
                                        First create an account on my website
                                        https://cabmaker32.com/login/
                                        Use those credentials with any of my plugins.
                                        Garry
                                        • ajharlanA Offline
                                          ajharlan
                                          I am scratching my head to try and figure this one out. I've tried multiple permutations of settings but cannot seem to get past this error. Any help appreciated.
                                          "Drawer System Error: Height < = 0"
                                            Garry K
                                            Contact me via Skype
                                            My Skype handle is:
                                            gkernan@telus.net
                                            • 31
                                            • 32
                                            • 6 / 32
