[Plugin] GKWare Cabinet Maker
Here is the same cabinet project but with the Cabinet Priority Optimizer turned off. You do save 1 sheet of material - but look at what happens.
Cabinet 1 can be assembled after the 25th sheet is processed.
Cabinet 2 can be assembled after the 30th sheet is processed.
Cabinet 3 can be assembled after the 29th sheet is processed.
Cabinet 4 can be assembled after the 12th sheet is processed.The crazy part is that you have to wait until the 30th sheet is processed before you can assemble 17 cabinets. Just look at the second last line.
CabMaker 6 and CutMaster 6 are now available on my web site.
Working on new version of CutMaster with an optimized parts distribution.
You can now set a sliding window which forces cabinet parts to complete machining in cabinet number order.With total disregard to cabinet number priority the tightest packing is 34 sheets for 32 cabinets with 3 drawer parts on sheet 34.
When honoring cabinet number priority (in this case the sliding window is set to
we still only require 34 sheets but there are now 13 parts on sheet 34.Here is the analysis of the 32 cabinets and their parts and the distribution of those parts onto sheets of material
Just wanted to thank Garry for some of the recent updates! Have wanted to for some time and just did not get around to it, apologies for not doing so sooner!
Not sure when it happened but always had to correct for drawer height in CutMaster in CabMaker drawers tab if they were to sit on drawer bottoms and noticed that no longer needs to be corrected for. Also In CutMaster had to add in Part Number as part of Part Name so it would show on the cutting layout diagram to make for easier location of parts in part listing when cutting pieces on table saw. Part number became part of the Layout display and saves me lots of time adding this to cabinet name.
Garry has always been great at assisting with any questions and I find he responds in very short order.
Thanks Garry!
@garry k said:
Currently not. However I have had a number of requests for sliding cabinet doors.
[attachment=0:28jea4ia]<!-- ia0 -->sliding doors.png<!-- ia0 -->[/attachment:28jea4ia]
Would love to have Sliding doors!
Have had projects in the past with sliding by-pass cabinet doors and currently working on one right now as well using CRL Laurence or Richelieu Hardware.
Billy - Thanks for your kind words.
Sliding doors is on my radar.New versions are now available on my website
CabMaker Version 6.0.150 – Feb 15, 2020
- Door report now has 2 new columns - Part Type and Material.
- Fixed Stretcher in Face Frame construction.
- Added Alt-D to give user the ability to delete templates - one at a time.
- Added Expression Evaluator.
- Cleaning up folders – simplifying.
- Scene generation Plan wasn't always working. Fixed.
CutMaster Version 6.0.1.94 - Feb 15, 2020
- Angled Tops and Bottoms - no backs - Fixed
- Import mapping modified in database
- Cleaned up 4 tables in database - no more fixed length characters
- Layout listing now adjusts sizing for extra room for small parts.
- DXF Reports now use adjusted size but without parts padding.
- Angled fixed shelves were not angled. Fixed.
Bill - Sliding doors are on my radar.
Currently working on CabMaker 6.0.151
Multi row door panels was flipped in Mid and Tall cabinets. Fixed.
Fixed rounding error with integrated kicks and notching
Renaming of Cabinet templates and Rule templates no longer deleting old name
Now working on Project level materials and rules
Todo:
- Finish Project level materials and rules
- Simplify adding textures
- c-channel and j-channel
- sliding doors
- merging - closets
- merging - face frames
The most current version of CabMaker is now available on my website.
Version 6.0.151 – Feb 29, 2020
- Multi row door panels was flipped in Mid and Tall cabinets. Fixed.
- Fixed rounding error with integrated kicks and notching.
- Renaming of Cabinet templates and Rule templates no longer deleting old name.
- Added PROJECT level for resources, Rules, Materials, Doors and Drawer Systems.
- Alt-S now works for all resouces.
- Dropped Alt-R, no need for rename since we have save as and delete.
- PROJECT tab now defaults to all tabs locked.
- Added Context help for resources.
Working on 6.0.152
Handless cabinets
I installed CabMaker on a new computer, but I keep on getting Web Service Error -25... How do I remove the license from the old PC and get it to work on the new one?
You need to email me requesting a reset. You must provide me with your userid.
CabMaker 6.0.152 is now available from my website.
- Added Handless Cabinet support.
- Modified Parts reports to include new handless information.
- Locks for new project are now in Edit Config.
- CabMaker kept adding same material to project - fixed.
I am now working on CutMaster to support the notching for handless cabinets.
CabMaker 6.0.155 is now available from my website.
Version 6.0.155 – Apr 20, 2020
- Cabinet merging now works better for face frame cabinets.
Version 6.0.154 – Apr 11, 2020
2. Standard Drawer backs not positioned correctly when back is sitting on bottom.
3. Door and Drawer tabs not updating when changing templates. Fixed
4. Now adding a message if reports have nothing to do - cabinet quantity = 0.Version 6.0.153 – Mar 31, 2020
- Edit Config now defaults to false for 'Locks on new project'.
CabMaker 6.0.157 and Cutmaster 6.0.1.99 are now available from my website.
CabMaker
Version 6.0.157 – Jun 19, 2020- Modified Merging for closets. Optionally the Left side for the right cabinet is the only panel that is changed. Backs, Tops, Bottoms, hangers are not modified.
Version 6.0.156 – Jun 7, 2020 - Modified Leg placement for Return Cabinets and Angled Ends.
- Modified CutMaster report for Side Dado.
CutMaster
Version 6.0.1.99 - Jun 19, 2020- Fixed Parts report when using fractions such as 16 29/64”. Had to increase the size of the Width and Length columns.
- Fixed merged panels for DXF. The left panel of the right merged cabinet now goes into a folder named “BackFace”.
- Modified Blind Mortise and Tenon for CNC. More control for handling tenon notches.
Version 6.0.1.98 - Jun 7, 2020 - Added Flip Tops, Flip Fixed and Flip Bottoms to General Options.
- Removed “Drill From Bottom”
- Completed Angled Ends for Blind Dado.
- Added Single line tenon cuts instead of pockets.
- Modified Leg positions for Return cabinets and Angled Ends.
- Added pocket option for Construction holes and Dowels. This supports Festool Domino and Lamelo.
Version 6.0.1.97 - May 11, 2020 - Configuration settings now has checkboxes to turn on / off DXF sections.
- You can now have any width of blind tenon (stop tenon).
- You can now set full dado width to 0 to get single line instead of a pocket.
- Bottoms, Tops, Stretchers, Fixed Shelves and rails can now have single line choice instead of pocket.
- For Blind Dado's added 4 new parameters, Depth Adjustment, Up Down Adjustment, Tenon Width Adjustment and Reverse Bottoms.
- Reverse bottoms is intended to be used with integrated kicks.
- Added Pocket Length to Construction Holes to support Festool Domino and Lamello.
- Added Start Line indicator for CNC view.
Now you have more control over Blind mortise and tenons.
Here are 2 examples with and without integrated kicks.
A new version of CabMaker is now available
Version 6.0.158 – Jul 1, 2020- Modified Sink cabinet. You can now have side by side drawer fronts without a stretcher.
A new versin of CutMaster is now available.
Version 6.0.1.101 Jun 30, 2020- Fixed drawer bottoms for single line routing directionality.
- Added pocket screws for drawer bottoms.
- Added optional X / Y offsets for routed label positioning.
Just installed the latest version. But once I try to run for first time the login dialogbox appears and ask for "hardware". If i use the ID and password registered at website but "hardware" field blamk. Sketchup freezes and the only way to starover is ctl+alt+del and kill the process.
Why?
Regards
I am currently helping him via email.
Good morning Garry, is there a way to change the door arc radius? I note that its set to 120 degrees as standard but I'd like to set it to 85-90 degrees.
Can't seem to find it anywhere in the manual.Cheers,
Try this
