Work in progress
Great start on an interesting piece ! Those hammered copper doors would look fantastic in a render.
Thank you, tuna. You're right about the render.
Nice work, David.
Finished.
Excellent!
Thanks, as always, Dave.
@davidheim1 said:
...Hope this helps...
A great result! Prima!
Thanks a lot David for your screenshots and explanations
- I can follow up to the polygonal shape outlines, from then on my in this case necessary translation tool speaks about some kind of foam rinse, which should only interest hairdressers
. Could you please guide me to the plugin tool you used here to generate these shapes? -
Thanks, HornOxx.
The lofting plugin I used is part of Fredo6's Curviloft, available through the Plugin Store here on SketchUcation. Here's a link:
Curviloft | SketchUcation
(sketchucation.com)
I used the Skinning plugin described in the link. It's also called Skin Contours, which apparently does not translate well. Apologies for the confusion.
Excellent finish !
@davidheim1 said:
...I used the Skinning plugin described in the link...
ouch!!! - how embarrassing for me. Curvi Loft is one of my favorite plugins. This right icon I have never tried before and have no idea why.
Thanks for your information and patience David
Plugins are so rich that it's very difficult to use all them functions!
I don't know, Frenchy. Dave Richards apparently has never met a plugin he didn't like.
