    Trying to find all edges on a face and weld
    18 Posts 4 Posters 3.8k Views 4 Watching
      blueman2
      @pilou said:
      Post the element that gives you problem (save as V6 for a more large audiance)
      Thanks for looking at this.
      Here is the part of the model that is giving me. Again, what I'm trying to achieve is an offset that I could create to add to the model so it would look like the photo I included above.
      I saved it in V6, I am running 2017, if that's of any help.
      Thanks again
      edge offset problem.skp
        Your object hole is definitly not on a plane!
        So you cant use the Offset tool!
          As the Tools on surface don't works...
          But I was not enough speedy! πŸ’š
            blueman2
            Thanks guys,
            I'm not familiar with that tool but will download it and play with it.
            So I can see that we are now projecting the shape onto a flat plane and I. guess, just using the offset tool, creating the trim around it that I want. But then, how do I get this new shape back onto the curved original surface? Is the projection tool then somehow used again to project this back onto that surface?
            Thanks again
            or (I'm editing this) is the new projection created also multi planar?
              The projection can go on any volume...
              Just Make Intersection
              et voilΓ ...
              And as your new Offset created is on a plane you can use with profit the VisuHole By Fredo πŸ˜‰
              For have more possibilities and facility! πŸ˜‰ Emboss, drill etc...
              Just take the filling form! πŸ˜‰
                As you see volume is traversed...VisuHole if top notch! πŸ˜‰
                  blueman2
                  @pilou said:
                  As you see volume is traversed...Visuhole if top noch!
                  Beautiful! Going to download the Visuhole tool also and try and learn both of the later today or tomorrow. Will post back, hopefully with a finished image
                  Thanks for your efforts
                    blueman2
                    OK, I was able to use the Projection plugin and create a stencil. Then I used the offset tool to create the edge trim that I want. I installed visuhole and think I can use Visuhole and the insertion points that are shown in the red arrow to place it in position (but I'm not sure, I haven't tried yet). However, what little I understand about this plugin leads me to believe that it will either drill a hole or make an embossed surface for this trim, rather than a material that would be on the same plane as the current surface of the guitar, which is really what it should be? Is that correct? Thanks
                      TBoy
                      See the PM,
                        blueman2
                        @tboy said:
                        See the PM,
                          TBoy
                          PM = Private Message
                            Maybe this can gives you more info for VisuHole on curvated surfaces! πŸ˜‰
