    [Plugin] MrHide (The Lost Toolbar) - v1.8a - 02 Apr 24
    25 Posts 9 Posters 14.1k Views 9 Watching
    • fredo6F
      The information on MrHide is maintained on the Plugin Home Page of MrHide. This is also where you can download the RBZ file.
      • LibFredo6: v14.3b or above
      • Usage: Free
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      MrHide is a Toolbarproviding direct access to functions which have no dedicated icons in Sketchup or are embedded deeply in the UI.
      In the current version, the functions are related to showing / hiding visual elements in SketchUp, most of them being style and scene parameters
      • hidden geometry, hidden objects, back edges
      • axes, component axes, dimensions, guides, text labels
      • shadow, sun shading, fog
      • Ground, Sky
      • dge visibility, Edge profiles, Edge endpoints, edge color by material, edge color by axis
      • Colors by tag / layer
      • Edit Component: show other instances and show rest of the model
      There is also a Quick Launcher.
      Based on an original idea by JClements, who also designed all the icons.
      No documentation. Please check tooltips of the icons and in the Quick Launcher dialog
      • F
        flyingphil
        Its got potential!
        Can you make Mr Hide show or hide the component axes?
        • fredo6F
          That's a possibility....
          • fredo6F
            NEW RELEASE: MrHide v1.2a - 28 Apr 20
            Requirement: LibFredo6 9.5
            MrHide 1.2a adds a few features for toggling visibility of
            • Component / Group axes
            • Ground, Sky
            • Colors by Tag / Layer
            Home Page of MrHide for information and Download.
            Main post of this MrHide thread.
            • F
              fedser
              Hi fredo6
              Great plugin, thanks. For a complete set, it would be useful to add similar functions...
              https://sketchucation.com/forums/viewtopic.php?f=323&t=49662
              This plug is apparently abandoned. These tools help a lot in complex scenes.
              Here it was upgraded for SU2020...
              https://extensions.sketchup.com/extension/64863c13-5cac-4514-b373-76b59278ef6a/vistools
              Many do not even know about its existence
              Give these tools a new life! Your plugin is perfect for this, thanks.
              • fredo6F
                1. I suggest you contact the author of VisTools (Dan Rathbun). He is still very active in Sketchup and post frequently on the Sketchup forum.
                2. In any case, this would be a different plugin than MrHide, which is really dedicated to toggling visibility for items which are buried in the Sketchup UI.
                • F
                  fedser
                  I have a "Vistools" plugin that works in SU2020. It was just a small suggestion to use all available tools "hide/show" in one plugin.
                  • fredo6F
                    NEW RELEASE: MrHide v1.3a - 30 Apr 20
                    Requirement: LibFredo6 10.3b
                    MrHide 1.3a adds a few features for toggling visibility of
                    • Back edges
                    • Edge endpoints
                    • Edge color by Material, Edge color by Axis
                    • kenK
                      ken
                      Hi fredo6
                      Unless I can't read, I find it interesting that there is no "Hide" tool, that you have to go to the context menu. It would be nice if the first button was the "Hide" tool.
                      Otherwise, I like how all the tools are in one location.
                      Thanks for the very professional work you have done for the Sketchup group.
                      • xayzerX
                        xayzer
                        Fredo, this plugin is so incredibly useful to me! Thank you ever so much for your incredible work!
                        It would also be totally rad if we had icons for Edges and Profiles.
                        Freelance Sketchup modeler, always looking for more work. Twitter: @Xayxer
                          db11
                          Just wanted to echo the appreciation for this plugin — and for your incredible contributions generally! I downloaded it yesterday and it's already saving me time and clicks showing and hiding.
                          Many thanks!
                          • fredo6F
                            NEW RELEASE: MrHide v1.4a - 03 May 20
                            MrHide 1.4a adds a few features for toggling visibility of
                            • Edge visibility
                            • Edge profiles
                            • xayzerX
                              xayzer
                              @jclements said:
                              Folks, I am working on Edge and Profile icons for Fredo this moment.
                              • Edge visibility
                              • Edge profiles
                              Holy crap, you guys actually did it! Thank you so, so much. This is a godsend as I'm constantly turning edges/profiles on/off in my workflow for certain projects, and I have a problem with my left arm where it's uncomfortable to move it around too much while working so I don't use many keyboard shortcuts and must rely on icons.
                              • xayzerX
                                xayzer
                                @jclements said:
                                I have a similar problem with my left shoulder; an artificial shoulder that has seen its last days. Quite painful and disabilitating at times.
                                Ah, man, I'm so sorry to hear that, JC. Hope there's a solution for that problem.
                                Mine is far less serious than yours. My left elbow is a bit wonky from years of resting it on an uncomfortable surface while working at the computer, and if I have to lift it up too much to reach for any shortcuts that aren't in the general left ctrl area, the pain starts to build up so I use only the very basic shortcuts.
                                Once again, thank you for your work on this plugin!
                                • jujuJ
                                  juju
                                  This is one of those extensions you think to yourself:" Self, nah, this functionality is already there, just clutter." Then you remember who the author is and think to yourself: "Self, you extensions snorting hippie, let's try it out." Now it is one of those extensions that you're soooo thankful for, saving you time and effort from the get-go.
                                  • JClementsJ
                                    JClements
                                    ". . . I have a problem with my left arm where it's uncomfortable to move it around too much ..."
                                    Glad to hear the toolbar helps you.
                                    I have a similar problem with my left shoulder.
                                    • JClementsJ
                                      JClements
                                      Folks, I am working on Edge and Profile icons at this moment.
                                      • fredo6F
                                        NEW RELEASE: MrHide v1.5a - 25 May 20
                                        Requirements
                                        • LibFredo6: v10.5a
                                        MrHide 1.5a brings a correct state of toolbar icons for Mac
                                        • B
                                          bharralure
                                          Bonjour Fredo
                                          Jutilise à la fois SU 19 et SU 20, sur lesquels j'ai installé Mr Hyde v1.5a et LibFredo6 v10.9a.
                                          Les vignettes que jaffichent dans la barre d'outils sont réduites à 6 pour SU 20, et 5 pour SU 19 (Affichage Objets Caché n'existant pas dans SU 19).
                                          Mon problème est le suivant : après avoir paramétré la barre d'outils depuis le lanceur rapide dans chacune des versions, puis relancé est refermé les deux versions, lors de la prochaine ouverture d'un fichier, nouveau ou existant, et peu importe la version, je me retrouve avec l'affichage de la barre d'outils complète, ce qui entraîne une désorganisation totale de l'ensemble des autres barres d'outils par manque de place.
                                          Le problème n'existe que sur la première version ouverte, la seconde conservant mes propres paramètres.
                                          Existe-t-il un remède Docteur ?
                                          D'avance merci pour une réponse.
                                          • fredo6F
                                            Il y a un remède. J'ai réussi à reproduire. C'est un effet de bord du fait que les Default Parameters sont communs à toutes les versions de Sketchup (pour rendre la migration à de nouvelles versions plus aisée).
                                            Je ferai une correction.
