    [Plugin Inquiry] Multiple pipe or profile extrusion plugin
    extensions
    9 Posts 4 Posters 3.9k Views 4 Watching
    • onzkiO Offline
      onzki
      Hi everyone! I'm fond of using pipe and extrude along path plugins. However, I needed something that can do multiple line selection at once. I'm trying to recreate a similar wavy trellis as inspired by Cincinnati John G. and Phyllis W. Smale Riverfront Park. Kindly refer to my screenshot. It will be a big time saver if I can use pipe along path (or shape extrusion) from multiple selection.
      Many Thanks!
      PS. should there be a similar inquiry with answer found, kindly forward to me the link, thanks!
      Plugin inquiry- Multiple selection pipe or profile follow-me
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
        Lines2tube by Didier Bur ?
        • BoxB Offline
          For that sort of design I would be using one of the component stringers.
            TBoy
            Box, how will you make similar configuration if start-points curve is different from end-points curve?
            For example - In your gif above you start with wave but you like ends to form an arc (or zig-zag line or anything).
            Is there a "stringer" with start and end points distribution curves (distributing profiles, not only tubes)?
            May be another solution is something like - "replace lines with components", is there any similar plugin?
            • BoxB Offline
              Tboy I don't understand the first question.
              As to your edit, sounds like Profile Builder 3.
                Take a look to this πŸ˜‰
                  Take a look to the Extrude Tools by Tig ...
                  • onzkiO Offline
                    onzki
                    Hi, thanks to every one for sharing your thoughts, I will check out and test those plugins you mentioned. Have a good day to all!
                      TBoy
                      Actually this is the same question as in the first post.
                      My wish is to have full control on curve points used for distribution of components (not only pipes).
                      Picture is made with lines + pipe plugin (Green elements has to be profiles).This way is not suitable for big number of profiles and more complex curves.
                      In your gif (with stringer plugin) we can not have full control on endings configuration (what I call "end-points curve").
