    [Plugin][$] s4u ImportDXF
    13 Posts 8 Posters 13.0k Views 8 Watching
    • hdpvH Offline
      hdpv
      s4u ImportDXF v1.0.0
      Import DXF file follow segment number(support MLINE,ELLIPSE,SPLINE,POLYLINE,CIRCLE,ARC,LINE)
      Download:
      http://sketchucation.com/pluginstore?pln=s4u_ImportDXF
      Video:
      Suforyou
      http://www.sketchupforyou.com
      • I Offline
        igorzai
        Not working. When I try to run it, the following message pops up:
        "Trial had expired.Contact:suforyou.vn@gmail.com for get a lisence."
        • jujuJ Offline
          juju
          And did you try what the message suggested? Outcome?
            athenapixie
            My s4u_import dxf shows ..."s4u_importdxf no actived. Do you have a Active File?" May I know what it means?
            • jujuJ Offline
              juju
              that sounds like it's looking for a licence
              • hdpvH Offline
                hdpv
                You install trial on Extension Warehouse:
                https://extensions.sketchup.com/en/content/s4u-import-dxf
                Suforyou
                • Q Offline
                  qmg
                  Why always with stray edges? Cant seem to beat this issue.
                  • hdpvH Offline
                    hdpv
                    Can you send your file to me? (vi@sketchupforyou.com)
                    Suforyou
                      mihirarch
                      only some objects gets imported so how do i have a full version of ur plugin if i want to buy
                      • hdpvH Offline
                        hdpv
                        You can trial and purchase on Extension Warehouse
                        https://extensions.sketchup.com/extension/f4854296-d400-4562-aff9-0e1e6a22fdf3/s4u-import-dxf-for-sketchup-pro
                        It just support Line,Dynamic Block,Mline,Ellipse,Spline,Polyline,Circle.
                        Suforyou
                        • LinearGraphsL Offline
                          LinearGraphs
                          Nothing loads when I import this:
                          Long 90°.DXF
                          Actually, it won't work for any of these.
                          Plumbing Fittings.zip
                          • hdpvH Offline
                            hdpv
                            Try save as Autocad DXF 2010 or later.
                            Update s4u ImportDxf v4.2.0 fix it.
                            Suforyou
                            • E Offline
                              Einstein
                              Hello,
                              Can you please add a dollar sign next to the plugin name in Plugin Store, so that we know right away that it is a paid plugin?
