    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      View models of arched doors here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      3D Warehouse
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.2.0b - 01.16.2020
        • Fixed a bug with wall presets introduced with the addition of the stud spacing offset parameter.
        ***** CRITICAL BUG FIX *****
        If you have previously installed Version 1.1.8 thru Version 1.2.0 then you will want to update your installation to this latest version. The bug was introduced into the wall presets module on 01/06/2020 when the stud spacing offset parameter was added. This bug fix should resolve that bug and allow the creation of wall presets with this latest parameter added to the list of wall parameters.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.2.1 - 01.17.2020
          • Added FLUSH:MITER and MITER:FLUSH option to the Wall Cladding Corners parameter.
          • Fixed a second bug with wall presets introduced with the addition of the stud spacing offset parameter.
          http://design.medeek.com/resources/trussplugin/images/truss_su625_800.jpg
          The additional options for the Wall Cladding Corners parameter is specifically for situations where you encounter a wall cladding material/thickness change at an inside corner as shown.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.2.1b - 01.17.2020
            • Added (segmental and half round) arched double doors to the door module.
            http://design.medeek.com/resources/trussplugin/images/truss_su626_800.jpg
            View model here:
            3D Warehouse
            design.medeek.com
              Glenn at home
              Looking good Nathan!
              • medeekM Offline
                medeek
                I've been considering add an advanced option for Quoins (outside corners only):
                https://aws1.discourse-cdn.com/sketchup/original/3X/e/a/ea8cec59ed5a90224595423ed0bcd18e3db59f6b.jpeg
                The required parameters would probably be:
                Style:
                Length 1:
                Length 2:
                Height:
                Spacing:
                Thickness:
                Material:
                View model here:
                3D Warehouse
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.2.1c - 01.17.2020
                  • Fixed a number of bugs related to stacked doors, door sidelites and backward compatibility with previous versions.
                  • Added (segmental and half round) arched half glass doors to the door module.
                  http://design.medeek.com/resources/trussplugin/images/truss_su629_800.jpg
                  Half glass option per customer request.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.2.1d - 01.18.2020
                    • Fixed the praire and perimeter grille style for arched half glass and full glass doors.
                    • Added (segmental and half round) arched full glass doors to the door module.
                    http://design.medeek.com/resources/trussplugin/images/truss_su630_800.jpg
                    It seems like there is always more with doors. The items still needing attention with the door module are:
                    • Option for transom window above rectangular and arched doors.
                    • Sidelites for arched doors.
                    • Additional door types for arched doors (ie. six panel, double half glass, double full glass etc...)
                    • Sliding doors
                    • Pocket doors
                    • Closet bi-fold doors
                    View model here:
                    https://3dwarehouse.sketchup.com/model/771d1d73-3aea-429f-99d8-caeb9c4c2fa3/Arch-Full-Glass-Doors
                    design.medeek.com
                    • jujuJ Offline
                      juju
                      Keep the main thing the main thing.
                      • medeekM Offline
                        medeek
                        It would actually be just another type of corner trim.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.2.2 - 01.25.2020
                          • Added (segmental and half round) arched half glass double doors to the door module.
                          • Added (segmental and half round) arched full glass double doors to the door module.
                          https://aws1.discourse-cdn.com/sketchup/original/3X/a/c/acf98db1261a18280611b3dd46da16ae68b0119b.jpeg
                          https://aws1.discourse-cdn.com/sketchup/original/3X/b/6/b61dfda7770c9fa4dc8980d434e97dd804a2ba86.jpeg
                          https://aws1.discourse-cdn.com/sketchup/original/3X/a/6/a68c703cded86d0e0427848d70438cfd33d2bdb3.jpeg
                          https://aws1.discourse-cdn.com/sketchup/original/3X/b/1/b15899668da857a32c2489122fcffe0a100df4b6.jpeg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.2.3- 01.30.2020
                            • Enabled up to four king and/or four trimmer studs for windows.
                            • Enabled up to four king and/or four trimmer studs for doors.
                            • Enabled up to four king and/or four trimmer studs for garage doors.
                            http://design.medeek.com/resources/trussplugin/images/truss_su637_800.jpg
                            http://design.medeek.com/resources/trussplugin/images/truss_su638_800.jpg
                            http://design.medeek.com/resources/trussplugin/images/truss_su639_800.jpg
                            Eight studs deep may seem a bit excessive but it's there if you need it.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.2.4 - 02.07.2020
                              • Fixed a bug with the gypsum wrap for rectangular and arched door openings of interior walls.
                              http://design.medeek.com/resources/trussplugin/images/truss_su643_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.2.4b - 02.08.2020
                                • Added a T1-11 built-in material into the material library.
                                • Fixed the move wall tool so that it no longer requires a negative number for offsetting to the exterior side of the wall.
                                • Enabled the display of the offset dimension next to the blue movement arrow for the move wall tool.
                                http://design.medeek.com/resources/trussplugin/images/truss_su644_800.jpg
                                The elimination of the negative offset should make the wall move tool a lot more intuitive to use. Please feel free to give me further feedback in this regard.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  In some cases you may frame up something like this:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/c/1/c1a0e2ca91722a1d3f7fd74c35243c083bb55765.jpeg
                                  Rather than a tee intersection you have two walls forming a corner and then a third wall tying in at the corner. Currently I really don't have a good solution for this scenario since one would probably need to offset the sheathing or gypsum back where the tertiary wall ties in.
                                  I will need to give this some further thought. Any ideas or suggestions are always welcome.
                                  I've identified a possible bug or issue where the top plate cutout algorithm tries to cut out a zero thickness slice from the adjacent top plate in this particular scenario, I will release a fix for that shortly.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.2.5 - 02.15.2020
                                    • Enabled custom materials (Material Library) for all doors and windows: Trim, Casing, Door Frame, Door, Window Frame, Shutters.
                                    • Addressed a minor bug with multiple walls coming together at a corner.
                                    http://design.medeek.com/resources/trussplugin/images/truss_su648_800.jpg
                                    ***** IMPORTANT WARNING *****
                                    This latest update is a necessary and major rewrite of the window and door modules. As such, this update will break compatibility with previous versions of the Wall plugin. It is highly suggested not to upgrade to this latest version for existing projects that were created with previous versions of the plugin.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.2.5b - 02.17.2020
                                      • Fixed a critical bug with the recently updated window and door edit menus.
                                      ***** IMPORTANT *****
                                      This is a critical bug fix to Version 1.2.5. When the source code was compiled for this version the updated HTML files (window and door edit menus) were somehow not updated as they should have been. I strongly suggest that you update from version 1.2.5 to version 1.2.5b, otherwise you may not be able to edit your windows and doors.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I apologize I was trying to upload Version 1.2.5b yesterday but for some reason I was unable to access the plugin store. I've noticed a number of upgrades and installations of Version 1.2.5 through out the day and this evening. Please upgrade to 1.2.5b since the previous version (1.2.5) has a critical flaw with the edit menus for both windows and doors and will not allow you to edit them. The problem was fully resolved with the fix in Version 1.2.5b.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Working on the Wall Stretch Tool this morning.
                                          Essentially I've boiled this tool down to a three click process:
                                          1.) Select the Wall that you want to stretch or shrink.
                                          2.) Select the start or end of the wall panel:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/7/c/7c77ea67edba293e66598a56c6dd5aca494c5a75.jpeg
                                          3.) Then select the new position of the wall start/end. (A wire frame is provided along with a dimension). The user can either select the position or key in the amount to stretch or shrink.
                                          This feature is in many ways related to the move tool since stretching a wall will also move any attached walls at the affect corner. Additionally when the start of the wall is moved the location of any features within the wall must be relocated so that they maintain their position, just a few things to think about.
                                          I've also setup the tool so that when you select the wall start or end you don't have to actually select within the circles shown. The tool will calculate how far your mouse click is away from each end and select the end which is closest to the mouse click.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.2.6 - 02.20.2020
                                            • Added a "Style C" trim option for rectangular windows.
                                            • Fixed a critical bug with the door module for metric templates.
                                            http://design.medeek.com/resources/trussplugin/images/truss_su651_800.jpg
                                            This particular trim style probably is best suited for a brick veneer cladding as shown.
                                            I may also create a Style D which looks similar but includes a keystone.
                                            design.medeek.com
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 74
                                            • 75
                                            • 35 / 75
