    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      @pilou said:
      I really see no reason to have a door over door algorithm either. Correct me if I'm wrong.
      No doors' emergency exit on the upper levels possible ?
      Yes, but in that case it will probably be a separate wall panel and not balloon framed to the second level.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.1.9 - 01.09.2019
        • Enabled stacked windows over doors within a wall panel.
        http://design.medeek.com/resources/trussplugin/images/truss_su619_800.jpg
        Note that for this to work correctly the king studs of the window(s) and door must align and the windows and doors must be centered on the same location within the wall.
        The framing, blocking and insulation modules are now updated for stacked windows and stacked windows over doors.
        design.medeek.com
        • medeekM Offline
          medeek
          As I was comparing the window and door modules this evening a number of things jumped out at me. I've made some updates over the last few months to the window module that did not get propagated to the door module. Here is a short list of items I will work on in the next couple of days to bring the door module up to par:
          1.) Arched, gothic arch and half round door openings and doors.
          2.) Variable king stud width for doors
          3.) Variable trimmer stud width for doors
          4.) Built up headers for doors
          5.) Trimmer extend option for doors (for built up headers that have a bottom plate, common construction method in Alberta CANADA).
          Note that these updates are specifically for man doors and do not apply to garage doors or garage door openings. That will be work for another day.
          *** IMPORTANT***
          I'm also considering making the wall plugin able to insert windows, doors and garage doors into generic walls (non-Medeek Walls), similar to what one is able to do with the electrical plugin. I actually don't think this will be too difficult and will make the Window/Door tools more universal and flexible for the user who may or may not always use Medeek walls in a given project.
          design.medeek.com
          • medeekM Offline
            medeek
            1 thru 5 of the items list previously are complete and now functional (not released yet).
            First look at an arched doorway:
            https://aws1.discourse-cdn.com/sketchup/original/3X/b/e/beda6c242859a9379b9eb9b20fa3c20edd1b40dc.jpeg
            I now need to complete the door trim, casing and install modules for an arched door. Eventually I will provide the option for all of the various door types (eg. six panel, half glass etc…) however to start with I will just enable the solid arched door.
            There will also be the permutation involving sidelites and double sidelites with arched doors, but again this will be work for another day.
            design.medeek.com
            • medeekM Offline
              medeek
              You can set the framing mode of the plugin to 2D or “no framing” 3D mode on a wall panel basis or even set the default behavior in the global settings.
              Once you are comfortable with your design you can switch the wall panels to the full framing mode. The no framing mode generates the wall framing as a single solid. Perhaps I need another tutorial that explains this in further detail. Switching between modes is completely automated, just one mouse click after you right click on the wall assembly(s).
              https://aws1.discourse-cdn.com/sketchup/original/3X/1/d/1d6329acae0a6c51ba92faeb88089e49982656cc.gif
              The idea behind the 2D and 3D No Framing modes is to keep the model as lightweight as possible during the early design phases (ie. don’t over complicate things with framing) while at the same time providing enough information to fully understand the design and its dimensional constraints/properties.
              The 2D mode is great for the initial layout but eventually one of the 3D modes will be required to fully grasp the various wall heights and possibly stacked window layouts etc…
              design.medeek.com
              • medeekM Offline
                medeek
                First look at an arched door frame and (solid) door:
                https://aws1.discourse-cdn.com/sketchup/original/3X/8/f/8f6a5472d21443210dde244ddde9f5598187e5d1.jpeg
                I think the only thing still pending is to make sure that wainscoting module can handle arched doors and then I will make this upgrade live.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.2.0  - 01.15.2019
                  • Added (segmental and half round) arched doors to the door module.
                  • Enabled variable king stud and trimmer stud widths for doors.
                  • Enabled built-up headers for doors.
                  • Enabled the trimmer extend option for doors.
                  • Added casing "Style C" for rectangle and arched doors (gypsum wrap for interior wall openings).
                  https://aws1.discourse-cdn.com/sketchup/original/3X/e/1/e1dad7cf0a96d8adc14ed0dd99f65bc8109e22ca.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/d/b/dbee1665e452bfe614e74a3fc9d29db1f1c8413b.jpeg
                  https://aws1.discourse-cdn.com/sketchup/original/3X/7/1/71366cc8453758742c08eeb3bc8eb7fa0aee9f72.jpeg
                  I've also addressed a few minor bugs and issues with both the door and window modules.
                  Currently the only arched door style is a "solid" door however I can add additional styles upon request (ie. half glass, double, full glass, six panel etc...)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    View models of arched doors here:
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.2.0b - 01.16.2020
                      • Fixed a bug with wall presets introduced with the addition of the stud spacing offset parameter.
                      ***** CRITICAL BUG FIX *****
                      If you have previously installed Version 1.1.8 thru Version 1.2.0 then you will want to update your installation to this latest version. The bug was introduced into the wall presets module on 01/06/2020 when the stud spacing offset parameter was added. This bug fix should resolve that bug and allow the creation of wall presets with this latest parameter added to the list of wall parameters.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.2.1 - 01.17.2020
                        • Added FLUSH:MITER and MITER:FLUSH option to the Wall Cladding Corners parameter.
                        • Fixed a second bug with wall presets introduced with the addition of the stud spacing offset parameter.
                        http://design.medeek.com/resources/trussplugin/images/truss_su625_800.jpg
                        The additional options for the Wall Cladding Corners parameter is specifically for situations where you encounter a wall cladding material/thickness change at an inside corner as shown.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.2.1b - 01.17.2020
                          • Added (segmental and half round) arched double doors to the door module.
                          http://design.medeek.com/resources/trussplugin/images/truss_su626_800.jpg
                          View model here:
                          3D Warehouse
                          design.medeek.com
                            Glenn at home
                            Looking good Nathan!
                            • medeekM Offline
                              medeek
                              I've been considering add an advanced option for Quoins (outside corners only):
                              https://aws1.discourse-cdn.com/sketchup/original/3X/e/a/ea8cec59ed5a90224595423ed0bcd18e3db59f6b.jpeg
                              The required parameters would probably be:
                              Style:
                              Length 1:
                              Length 2:
                              Height:
                              Spacing:
                              Thickness:
                              Material:
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.2.1c - 01.17.2020
                                • Fixed a number of bugs related to stacked doors, door sidelites and backward compatibility with previous versions.
                                • Added (segmental and half round) arched half glass doors to the door module.
                                http://design.medeek.com/resources/trussplugin/images/truss_su629_800.jpg
                                Half glass option per customer request.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.2.1d - 01.18.2020
                                  • Fixed the praire and perimeter grille style for arched half glass and full glass doors.
                                  • Added (segmental and half round) arched full glass doors to the door module.
                                  http://design.medeek.com/resources/trussplugin/images/truss_su630_800.jpg
                                  It seems like there is always more with doors. The items still needing attention with the door module are:
                                  • Option for transom window above rectangular and arched doors.
                                  • Sidelites for arched doors.
                                  • Additional door types for arched doors (ie. six panel, double half glass, double full glass etc...)
                                  • Sliding doors
                                  • Pocket doors
                                  • Closet bi-fold doors
                                  View model here:
                                  https://3dwarehouse.sketchup.com/model/771d1d73-3aea-429f-99d8-caeb9c4c2fa3/Arch-Full-Glass-Doors
                                  design.medeek.com
                                  • jujuJ Offline
                                    juju
                                    Keep the main thing the main thing.
                                    • medeekM Offline
                                      medeek
                                      It would actually be just another type of corner trim.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.2.2 - 01.25.2020
                                        • Added (segmental and half round) arched half glass double doors to the door module.
                                        • Added (segmental and half round) arched full glass double doors to the door module.
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/a/c/acf98db1261a18280611b3dd46da16ae68b0119b.jpeg
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/b/6/b61dfda7770c9fa4dc8980d434e97dd804a2ba86.jpeg
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/a/6/a68c703cded86d0e0427848d70438cfd33d2bdb3.jpeg
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/b/1/b15899668da857a32c2489122fcffe0a100df4b6.jpeg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.2.3- 01.30.2020
                                          • Enabled up to four king and/or four trimmer studs for windows.
                                          • Enabled up to four king and/or four trimmer studs for doors.
                                          • Enabled up to four king and/or four trimmer studs for garage doors.
                                          http://design.medeek.com/resources/trussplugin/images/truss_su637_800.jpg
                                          http://design.medeek.com/resources/trussplugin/images/truss_su638_800.jpg
                                          http://design.medeek.com/resources/trussplugin/images/truss_su639_800.jpg
                                          Eight studs deep may seem a bit excessive but it's there if you need it.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.2.4 - 02.07.2020
                                            • Fixed a bug with the gypsum wrap for rectangular and arched door openings of interior walls.
                                            http://design.medeek.com/resources/trussplugin/images/truss_su643_800.jpg
                                            design.medeek.com
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 75
                                            • 76
                                            • 70 / 76
