    [Plugin] Virtual Assistant - v1.0.2 - 28 Dec. 2019
    13 Posts 4 Posters 4.7k Views 4 Watching
    • samuel_tS Offline
      samuel_t
      What's new in 1.0.1 version?
      • Chat bot understands following sentences*:
      Open a file.
      Select first entity.
      Select first group.
      Select first component.
      Move selection 1m along X axis, 1m along Y axis and 1m along Z axis.
      Rotate selection by 90 degrees.
      Increase selection size 2 times.
      • There is a "Virtual Assistant" toolbar in SU.
      (*) Sentences are customizable.
      Download latest Virtual Assistant plugin from SketchUcation PluginStore.
        Anton_S
        Whoa! That's some nice work there. I can't wait to check it out. This has so much potential.
          Anton_S
          Is there a way to enable microphone? It would be good if it listens for your messages while the chat box window is minimized or not active.
          • samuel_tS Offline
            samuel_t
            Thank you Anton! Let me know if you have ideas.
            I found no way to enable microphone for now! 😞
              Anton_S
              I have a few ideas, including:
              • Selecting an entity with name: select entity SomeEntityName
              • Look at entity with name
              • Zoom extents at entity with name / selected
              • Delete entity with name/selected
              • Active tool [ToolName]
              If you google JavaScript speech to text, you should see a number of solutions and libraries. For example, check out https://tutorialzine.com/2017/08/converting-from-speech-to-text-with-javascript
              If user says an unrecognizable command, list a number of commands the are similar; allow creating aliases.
              • samuel_tS Offline
                samuel_t
                @Anton_S
                Thanks again!
                • samuel_tS Offline
                  samuel_t
                  Good news: next version will include speech recognition. πŸ˜›
                  • samuel_tS Offline
                    samuel_t
                    What's new in 1.0.2 version?
                    • Chat bot listens to your voice/microphone.
                      This requires Windows 64 bits & Chrome 25+.
                    • Chat bot understands following sentences:
                      • Select group with name ...
                      • Select instance with name ...
                      • Name ...
                      • Duplicate and name ...
                      • Clear selection.
                      • Delete.
                      • Activate Push Pull tool.
                      • Activate Rectangle tool.
                      • Activate ... tool.
                      • Write ...
                    • A "Did you mean" algo. was implemented.
                    • Chat bot understands somewhat quantities.
                      Anton_S
                      Nice! I tried the update with the microphone option and it works quite well. I do realize it is much faster to do things without saying but this can always be expanded to perform more complex operations.
                      • F Offline
                        faust07
                        It is amazing when geniuses are found. I am thrilled and can hardly wait for the results. I would be particularly excited about the synergies for the MSPhysics area - voice input ...
                        Thanks again!
                          bigfoot03242
                          This is a great Idea Does it use only windows is tht an additional function of cortana or narrator
                          • samuel_tS Offline
                            samuel_t
                            It uses Google Chrome Speech Recognition.
