    [Plugin] Virtual Assistant - v1.0.2 - 28 Dec. 2019
    13 Posts 4 Posters 4.1k Views 4 Watching
    • samuel_tS Offline
      samuel_t
      Hello! πŸ˜„ I created a plugin that allows you to interact with SketchUp (in English) with voice or text. Speech recognition is only available on Windows. Let me know if you want bot handle more actions.
      => You can download it from SketchUcation PluginStore.
      Demos
      VAT Plugin Chat Demo #1
      VAT Plugin Chat Demo #2
      • samuel_tS Offline
        samuel_t
        What's new in 1.0.1 version?
        • Chat bot understands following sentences*:
        Open a file.
        Select first entity.
        Select first group.
        Select first component.
        Move selection 1m along X axis, 1m along Y axis and 1m along Z axis.
        Rotate selection by 90 degrees.
        Increase selection size 2 times.
        • There is a "Virtual Assistant" toolbar in SU.
        (*) Sentences are customizable.
        Download latest Virtual Assistant plugin from SketchUcation PluginStore.
          Anton_S
          Whoa! That's some nice work there. I can't wait to check it out. This has so much potential.
            Anton_S
            Is there a way to enable microphone? It would be good if it listens for your messages while the chat box window is minimized or not active.
            • samuel_tS Offline
              samuel_t
              Thank you Anton! Let me know if you have ideas.
              I found no way to enable microphone for now! 😞
                Anton_S
                I have a few ideas, including:
                • Selecting an entity with name: select entity SomeEntityName
                • Look at entity with name
                • Zoom extents at entity with name / selected
                • Delete entity with name/selected
                • Active tool [ToolName]
                If you google JavaScript speech to text, you should see a number of solutions and libraries. For example, check out https://tutorialzine.com/2017/08/converting-from-speech-to-text-with-javascript
                If user says an unrecognizable command, list a number of commands the are similar; allow creating aliases.
                • samuel_tS Offline
                  samuel_t
                  @Anton_S
                  Thanks again!
                  • samuel_tS Offline
                    samuel_t
                    Good news: next version will include speech recognition. πŸ˜›
                    • samuel_tS Offline
                      samuel_t
                      What's new in 1.0.2 version?
                      • Chat bot listens to your voice/microphone.
                        This requires Windows 64 bits & Chrome 25+.
                      • Chat bot understands following sentences:
                        • Select group with name ...
                        • Select instance with name ...
                        • Name ...
                        • Duplicate and name ...
                        • Clear selection.
                        • Delete.
                        • Activate Push Pull tool.
                        • Activate Rectangle tool.
                        • Activate ... tool.
                        • Write ...
                      • A "Did you mean" algo. was implemented.
                      • Chat bot understands somewhat quantities.
                        Anton_S
                        Nice! I tried the update with the microphone option and it works quite well. I do realize it is much faster to do things without saying but this can always be expanded to perform more complex operations.
                        • F Offline
                          faust07
                          It is amazing when geniuses are found. I am thrilled and can hardly wait for the results. I would be particularly excited about the synergies for the MSPhysics area - voice input ...
                          Thanks again!
                            bigfoot03242
                            This is a great Idea Does it use only windows is tht an additional function of cortana or narrator
                            • samuel_tS Offline
                              samuel_t
                              It uses Google Chrome Speech Recognition.
