    Flowscape ! :)
    25 Posts 5 Posters 10.3k Views 5 Watching
      Little tricks: Alt + Right Clic and move the mouse for rotate at the place of the click!
      TAB for accelerate movements
      https://i.postimg.cc/9MvbkyVZ/GIF-rotate-flowscape.gif
      https://i.postimg.cc/d3pBHtJp/hiv01.jpg
      • G
        Glenn at home
        Here's one I did with a model of Amon Hen I down loaded from the web.
        • pbacotP
          I really wish I could do my rendering environments this way. You can't export it. Maybe I could put my buildings INTO it instead.
          • G
            Glenn at home
            This is how I have done it so far. I export to .obj and make sure the textures and obj are in the same folder.
            I then bring the file into Blender to check the textures. I also do a bit of scaling to bring down the size. I save to obj again.
            Then bring it into Flowscape. Not always 100% but getting better.
              Tiny Planet by Chacha (100 free projects/Month)
              Same in 360ยฐ by Chacha
              else 15 seconds for this one (houses + big Christmas tree) rest is automatic! ๐Ÿ˜„
              Really amazing! ๐Ÿ˜Ž
              https://i.postimg.cc/281Kvwww/15-s.jpg
                How easy to Sculpt, Texture, put Flowers... ๐Ÿ˜ฎ
                https://i.postimg.cc/Sxghbrx0/Truffo01.jpg
                  Full of animals! ๐Ÿ˜„
                  https://i.postimg.cc/SNd82DL1/GIF-suri.gif
                    If you want make a panorama you must enable Adaptative Quality!
                    because there is a bug on the "Capture Panorama" function!
                    Like that no problem for the Tiny Planet! ๐Ÿ˜„
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/save-adaptative_orig.jpg
                    Here following just 3 seconds test! ๐Ÿ˜„ (free 100 Projects / Month)
                    Panorama 360ยฐ or Tiny Planet on the Full Screen!
                    https://kuula.co/share/7vbXS
                    https://kuula.co/share/7vbc8
                    Simple fixed still Image
                    https://kuula.co/share/7vbGZ
                      Totally dizzy! I must unplug! ๐Ÿ˜ฎ
                      https://i.postimg.cc/TPSNnCc6/vert-igineux.jpg
                        No direct transparency! ๐Ÿ˜ฒ
                        https://sketchucation.com/forums/download/file.php?id=157973
                        gs
                        but with some manual editing seems we can have some transparency and other cool thongs! ๐Ÿ’š
                        https://i.postimg.cc/Njkt3C1x/tranpaFS.jpg
                          ๐Ÿ˜‰
                            https://i.postimg.cc/15BF8k42/landscpei.jpg
                            Maybe next 360 Landscape will be more refined! ๐Ÿ’š
                            Try Spherical view and Tiny Planet up right page Menu
                              A funny free workFlow...Scape
                              From BricsCad Shape or Sketchup Make 2017! ๐Ÿ˜‰
                              Better to make textures etc inside PCon Planner! It's catalog is cornucopia! ๐Ÿ˜Ž
                              https://i.postimg.cc/hvTVfvNq/parquet1.jpg
                              https://i.postimg.cc/150pSgpG/Parquet2.jpg
                              https://i.postimg.cc/R0YtdwBB/parquet3.jpg
                              https://i.postimg.cc/x8DzDY8p/pcox.jpg
                              https://i.postimg.cc/ZRJGfvFw/GIF-jaune-vert.gif
                              • ntxdaveN
                                ntxdave
                                Thanks for sharing Pilou. The Christmas North Pole video is very nice and stimulating. Sure is appropriate for the season. ๐Ÿ‘
                                I would love to be able to create something like this as an animated Christmas card and share it with others.
                                Press F1...thank me later
                                  Free models for personal use by 600v, Ixlrlxi alias Rust Shake at https://www.patreon.com/600v
                                  As it's SKP formats use the fabulous Free Pcon Planner for texture and Conversion in OBJ https://pcon-planner.com (for who have no SU) you can use textures, materials and even objects from its incredible catalog! ๐Ÿ˜„
                                  Here in the funny and easy Flowscape in 10 seconds...
                                  https://i.postimg.cc/ZKFCnxTH/cop.jpg
                                  https://i.postimg.cc/sXh2rp6p/op1.jpg
                                  • ntxdaveN
                                    ntxdave
                                    Pilou, dumb question: are these screen captures or is there a way to generate an image? I read there is now a way to create a 360 pano view but I have not been able to find any other info about exporting your work.
                                      Here above it was snaptshot screens but i can of course make a 360ยฐ directly inside FlowScape! ๐Ÿ˜Ž
                                      Just click this button "Capture Panorama" with "Adaptative Quality" enabled! ๐Ÿค“
                                      (without "quality adaptative" you will have bad result because there is bug! )
                                      Like mine for example here ๐Ÿ˜‰ Try also the icon "Tiny Panet" (Up Page right menu) โ˜€
                                      And after you must have something for read this 360ยฐ like this Kuula site (100 free projects / Month) ๐Ÿ˜Ž
                                      The pano is something like this!
                                      If you want just a photo click this button following! ๐Ÿ˜‰
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/section22_orig.jpg
                                      • ntxdaveN
                                        ntxdave
                                        Thanks for the feedback Pilou. Did not know you can also create an image. I will look into this a little more later. ๐Ÿ‘
                                          A SketchUp greebling ๐Ÿ˜„
                                          so...
                                          https://i.postimg.cc/65CLXZZr/greeble.jpg
                                            Some researches! ๐Ÿ’š (better in big zoom)! ๐Ÿค“
                                            Happy new year! ๐Ÿ˜Ž
                                            https://i.postimg.cc/FFJhcr1F/fascp01.jpg
                                            https://i.postimg.cc/15GPCvpL/fascp02.jpg
                                            https://i.postimg.cc/K8mbdtf4/fascp03.jpg
                                            https://i.postimg.cc/RZGm9qpd/fascp04.jpg
                                            https://i.postimg.cc/43dg3Zrg/fascp05.jpg
                                            https://i.postimg.cc/rs6Xg4zV/fascp06.jpg
                                            https://i.postimg.cc/529cPb9C/fascp07.jpg
                                            https://i.postimg.cc/RZgkyyqb/fascp08.jpg
                                            https://i.postimg.cc/Gp9WCKy3/fascp09.jpg
                                            https://i.postimg.cc/k5ZkXSQQ/fascp010.jpg
                                            https://i.postimg.cc/TwDByP0Z/fascp011.jpg
                                            https://i.postimg.cc/d3cpGKSD/fascp012.jpg
                                            https://i.postimg.cc/Rh18Rbjd/fascp013.jpg
                                            https://i.postimg.cc/RCwj4NNt/fascp014.jpg
                                            https://i.postimg.cc/Jhy2ghfG/fascp019.jpg
                                            [img:3mx37nkj]https://i.postimg.cc/s2tNRrzK/fascp020.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/MHYPRfQr/fascp023.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/SQLtH3v7/fascp024.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/qMkZrQff/fascp025.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/gkNt2Rdx/fascp026.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/Gmt782hq/fascp027.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/Bnzhx0js/fascp028.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/zfRx7chh/fascp029.jpg[/img:3mx37nkj]
                                            [img:3mx37nkj]https://i.postimg.cc/V6QDVW9V/fascp030.jpg[/img:3mx37nkj]
