Flowscape ! :)
Perfect for the pleasure of the eyes and relaxation! ( ~ 8 to 12 $)
You can import your models fbx OBJ, export a 360°https://pixelforest.itch.io/flowscape
nice find
Yep cool little "game" Been playing with it for a while.
Music inside!
Import fine OBJ format but not FBX ( FlowScape from Steam)
With MagicaVoxel
The original is moving in the wind!
Little tricks: Alt + Right Clic and move the mouse for rotate at the place of the click!
TAB for accelerate movements -
Here's one I did with a model of Amon Hen I down loaded from the web.
I really wish I could do my rendering environments this way. You can't export it. Maybe I could put my buildings INTO it instead.
This is how I have done it so far. I export to .obj and make sure the textures and obj are in the same folder.
I then bring the file into Blender to check the textures. I also do a bit of scaling to bring down the size. I save to obj again.
Then bring it into Flowscape. Not always 100% but getting better. -
Tiny Planet by Chacha (100 free projects/Month)
Same in 360° by Chacha
else 15 seconds for this one (houses + big Christmas tree) rest is automatic!
Really amazing! -
How easy to Sculpt, Texture, put Flowers...
Full of animals!
If you want make a panorama you must enable Adaptative Quality!
because there is a bug on the "Capture Panorama" function!
Like that no problem for the Tiny Planet!Here following just 3 seconds test! (free 100 Projects / Month)
Panorama 360° or Tiny Planet on the Full Screen!
https://kuula.co/share/7vbXSPanorama 360° or Tiny Planet on the Full Screen!
https://kuula.co/share/7vbc8Simple fixed still Image
https://kuula.co/share/7vbGZ -
Totally dizzy! I must unplug!
No direct transparency!
gsbut with some manual editing seems we can have some transparency and other cool thongs!
Maybe next 360 Landscape will be more refined!
Try Spherical view and Tiny Planet up right page Menu
A funny free workFlow...Scape
From BricsCad Shape or Sketchup Make 2017!
Better to make textures etc inside PCon Planner! It's catalog is cornucopia! -
Thanks for sharing Pilou. The Christmas North Pole video is very nice and stimulating. Sure is appropriate for the season.
I would love to be able to create something like this as an animated Christmas card and share it with others.
Free models for personal use by 600v, Ixlrlxi alias Rust Shake at https://www.patreon.com/600v
As it's SKP formats use the fabulous Free Pcon Planner for texture and Conversion in OBJ https://pcon-planner.com (for who have no SU) you can use textures, materials and even objects from its incredible catalog!
Here in the funny and easy Flowscape in 10 seconds...
