    VisuHole punched stencil as component
    20 Posts 3 Posters 5.3k Views 3 Watching
      And if you need models go there ...https://www.mcmaster.com for any mechanical pieces! ๐Ÿค“
      I suppose they have bolts Nuts & rivets! ๐Ÿ˜„
      https://i.postimg.cc/zfG8Bs5Z/fft.jpg
      For Sketchup use the Sat Format and the Free PCON Planner for make the SKP format! ๐Ÿ˜„
      https://i.postimg.cc/0QMGdPh1/satsat.jpg
      You can use the free Real Time Render SimLab Composer Lite ๐Ÿ˜‰ (maxi 1920 * 1080)
      https://i.postimg.cc/6pGQwJ9H/stepbest1.jpg
      Here with a Nurbs prog...
      https://i.postimg.cc/MK3cqm1G/step-best.jpg
        rafikius
        @box said:
        Are the two hundred holes in a circle?
        Gosh.. yes they are!
        The simplest methods are the best. No need for any plugins.
        I got my mind fixed in one way and you showed me another-simpler
        https://lh3.googleusercontent.com/gJT1w9rJqPXLFDNJh4I3rAp3W6Bu4nc8JoKfFVUHGreRM0J0qBm9WCoC1t-b4b97nrfA6enUnsyfQ7ijKSfwukidf66HEZnkaMsDoda6taKPQRWCRYrCnk2XLgg_myX5dLtkKP47eQ=w2400
        • BoxB
          Glad you got there.
          This is why we ask to see what you are working on, if we'd known it was a simple array when you first asked we could have shown you then. I thought from your original reference to using Copy along curve that the flange wasn't round.
            rafikius
            @box said:
            Glad you got there.
            I got familiar with the "golden rule" (posting the model with a post) right after I sent my post, only. Mea Culpa ๐Ÿ˜•
            And I solved one more issue that bothered from a certain time, ie. how to embed in one's post a google photos based image
            and for future viewers of this post...
            Thou my way to complete the task was a way around.
            I still can not figure out why a hole made with fredo's visuhole extension & copied using rotate method does no result in copied holes but pipes with a blinded ends.
            like that:
            https://lh3.googleusercontent.com/r_fe8gk_5JG6n07-1Hdewrjn_hU2tkCpkob7yt14x2bMiUanbTf1mK0Zp7FN_UXlJafwEGBzlvkOnykGHIozWySvBJkrnAyue8mZYq_eR3zr86csdBAA_0ZXeLytEj07YsteyHN_lA=w2400
            The "empty hole" is the one created with VisuHole. the rest are its copies
            (I set the VisuHole plugin to place the result as a group.)
            The one its left is a copy which I had to "intersect with model" with and only then I could manually remove the "blin end".
            AFAIU the rotate tool shall allow copying a group/component.
            What am I missing?
            • BoxB
              Creating 'holes' in a thickness is often problematic, it is far easier to make the holes in one face and then extrude.
                I believe you can only move (and trim) automatically only all the holes in the same time!
                or one or some of them but not a copy!
                  For your problem of copy of an cutting VisuHole Object
                  Select your single or multiple result Visuhole Object(s)
                  Make a component with Everywhere Cutting link
                  Copy and move it from the background to the Face
                  Explode it (don't ask me why...๐Ÿ˜„
                  Kill the original
                  Use the Hole Punch Tool by Tig Regulate the deepth
                  You can now copy and Or Move anywhere you want on the face that will Cut the face Front to Back!!
                  That all ๐Ÿ˜„
                    rafikius
                    Kill the original
                    My Lord..! ๐Ÿ˜ฎ
                    How did you come up to such scheme ๐Ÿ˜„ ?
                    Have you been spending months playing with various methods ๐Ÿ˜„
                    Going to give a try to this "direct method" ๐Ÿ˜„
                    Respectful hat tips
                      In fact that is because my original had a centered volume included face!
                      And the Tig Plug take only "extnernal surface" !
                      else it's not exactly perfect because the internal volume is not dupplicated! ๐Ÿ˜ž ๐Ÿ˜„
                      I must dig that! ๐Ÿ˜„
                        Ok you have an easy solution but you must have a Pro version or better Booltools 2 ๐Ÿ˜‰
                        Booltool2 works without the Pro Version of SU ! (it's not free but it's a very cool tool! ๐Ÿ‘ )
                        Make your Visuhole object module
                        (video begins here)
                        Move it out in the space from your global original Object
                        Scale it in One direction from Center (+ CTL) (not good works if you have just aligned objects faces)
                        Group it
                        Group your Principal object
                        You can now make any Boolean operations after any copy, move module ...
                        If you want make multiple Boolean objects group them before as follow!
                        White box is Object 1
                        Group of 3 groups is Object 2 for only one Diff Bolean Operation
                        (use second icon of Booltools2 )
                        Click on image for animation
                          Else you have this cool opener by Didier Bur for simple multiple drills not intersected with existing holes !
                          (don't works on Group or component)
                          Select "only surface(s)" not the edges ! Menu Extension "Hole"
