    Componentes dinsmicos para carpinteros
    Scheduled Pinned Locked Moved Dynamic Components
    5 Posts 2 Posters 6.9k Views 2 Watching
    • G
      Gianmartin
      Componente dinamicoHola a todos
      No se si alguien pueda darme una idea de como hacer lo que esta en el video
      mil gracias
      • P
        pcmoor
        can not see anything on the video, can you upload link to you tube?
        • G
          Gianmartin
          https://youtu.be/QHpNqYM17MI
          Envio link youtube
          • P
            pcmoor
            There are two ways to create this, one is to use parts and hide the common edges and faces, the other is to use cutting components
            In this case its parts and hidden faces/edges as shown @ 2.04 on video
            you can see the outline of the end face/component when the offset is matched to the thickness with a given back thickness,
            When you create such. I recommend you use solids then can outer-shell the subs to create a whole (retaining the parent for data and ability to reinstate with swap with its definition)
            cutting components work if the edges are hidden (outlines can be added as dynamic groups or components)
            Either way, it involves making sub components or (I prefer) groups to suit your purpose
            • G
              Gianmartin
              Ok, muchas gracias por la informacion, voy a intertar hacer lo que me dices y estare informando los resultados
