    Solar panels not dropping at desired tilt
    1 Posts 1 Posters 1.7k Views 1 Watching
    • P
      ppelletier
      Hello. I am new to the forum and look forward to learning from my time here. I usually have been able to work through problems I encounter with my models but this one has me stumped.
      I am dropping solar modules on a 3D mesh with the tilt of 31 degrees. This is not a flat surface but a slope. After dropping, the panels end up vertical on my 3D model. It does not matter if I select tilt or relative tilt when placing the modules nor does it matter if I select "drop coplaner to the surface" or "drop without rotation". I have tried different modules, changing the camera perspective, deleting and replacing the modules to no avail.
      I have been able to perform this function on other models but for some reason not on this particular model.
      Thank you for any guidance you can give me.
