    3D Truss Models
    1.5k Posts 31 Posters 977.2k Views 30 Watching
    • O Offline
      OliVDB
      Thanks for the thread and the explanation, that's extremely useful for us newbies! Especially since I got a task that's a little bit out of my league at work: do some 3D models for some of this Cannes real estate, while I'm glad if I can do something like an ice cream cone or a basic child drawing house...
      • medeekM Offline
        medeek
        Lots of little details when it comes to editing roof planes. First of all let's introduce an updated menu:
        http://design.medeek.com/resources/trussplugin/images/truss_su541_800.jpg
        Notice that the roof plane status will tell you whether the selected roof plane is inheriting its parameters from the main roof or it has its own custom settings.
        I've also added a "Clear Custom Settings" at the bottom of the menu so that one can return the roof plane to the default/global settings of the roof assembly.
        Setting up all of this supporting infrastructure is somewhat tedious and certainly time consuming, however I do believe that a solid user interface that is both efficient and intuitive will make or break this module.
        I intend for the edit plane tool to be persistent, provided that it does not affect stability. In other words you can keep clicking on roof planes and updating them without having to restart the tool by clicking on the icon in the toolbar.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          After struggling with the code for almost 8 hours I give you a fully parametric, asymmetric complex roof (primitive):
          http://design.medeek.com/resources/trussplugin/images/truss_su542_800.jpg
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          I will now need to spend a day or two just trying to break it and I also need to enable the gable end option.
          All of the menus and tools are working correctly now and seem to be quite robust. I will spend the next couple of days finishing up the roof primitive geometry (and testing). After that I would like to enable sheathing and cladding along with the roof labels and then I will probably release an update so everyone can test it out further and help me unearth any bugs I may have missed.
          design.medeek.com
          • medeekM Offline
            medeek
            If you take a look at these two roofs you will notice that in the second case the lower ridge has degenerated into the steeper roof plane:
            http://design.medeek.com/resources/trussplugin/images/truss_su544_800.jpg
            http://design.medeek.com/resources/trussplugin/images/truss_su543_800.jpg
            I didn't think it was possible but there are certain configurations where a standard straight skeleton will not generate the expected roof. This is a good example of that.
            The complex roof module will not be able to automatically handle these types of situations.
            This is where the secondary roof module will need to come in.
            design.medeek.com
            • medeekM Offline
              medeek
              Throwing all sorts of curve balls at this module to see if I can break it. Ultimately one can always break anything if you try hard enough, especially with something as complex as some of these roofs get.
              Overall I'm pretty happy with it, I've addressed the issue with inside corners and now all is working as expected. Here is a recent test example of a roof with planes and pitches all over the place:
              http://design.medeek.com/resources/trussplugin/images/truss_su545_800.jpg
              View model here:
              3D Warehouse
              That being said there is always further testing that can be done. I'm sure there is some state I have not thought of that someone will get the plugin into that will break it.
              I think it is time to move on to the gable end option. Once I get that working I think the utility of this new module will start to become apparent.
              design.medeek.com
              • medeekM Offline
                medeek
                I haven't quite started into the framing geometry just yet but I'm already one step ahead thinking about how certain junctions are going to need to be framed up.
                Two hip rafters meeting at a ridge is pretty standard and I think I have that one handled however the junction where a valley rafter meets a flying hip and ridge is a little more uncertain. Any information on how some of these framing junctions should be made would be very helpful.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Gable End option (within the edit roof panel menu) is now providing stable results:
                  http://design.medeek.com/resources/trussplugin/images/truss_su546_800.jpg
                  View model here:
                  3D Warehouse
                  The roof primitive module for asymmetric complex roofs with gable and hip ends is now complete. Granted there is still room for additional options like dutch gable and half hips but I will leave those for another day.
                  I will now turn my attention to sheathing and cladding as well as the roof plane labels (name and sqft).
                  One thing I forgot to add into the overall roof parameters/options is anything for battens and cross battens. I can add it in if I receive some positive feedback on that feature, otherwise I will move on and start into the sheathing module first thing tomorrow.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.5.1 - 10.02.2019
                    • Enabled the "Edit Roof Plane" tool, allowing for customized roof planes within complex roof assemblies.
                    • Added the gable end option for complex roofs within the "Edit Roof Panel" tool/menu.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.5.1b - 10.03.2019
                      • Added logic so that customized roof planes can co-exist with the "Move Roof Edge" and "Edit Roof Outline" tools of the complex roof module.
                      Previously, moving roof edges would potentially shift the customized roof planes if certain roof edges were removed or consolidated. I think we have now achieved a fully parametric status with the various tools all working together.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        After giving it some further consideration I’ve decided to enable dutch gable and half hip options for custom roof planes rather than leave it for later. If I include these options now it will force me to keep my other more specific algorithms general enough to handle all cases. The geometry calcs required to generate the roof primitive for these two other configurations is really not that difficult and actually provides a rather intriguing challenge.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First look at half hip complex roofs:
                          http://design.medeek.com/resources/trussplugin/images/truss_su548_800.jpg
                          (textures added to roof primitive for effect)
                          Notice the additional "setback" parameter in the menu. Also a half hip roof plane has both hip and gable parameters with the non-applicable parameters grayed out, as shown.
                          Similar to a gable end, the half hip can only be applied to certain roof planes, the plugin automatically restricts this placement.
                          The overhang of the half hip is governed by the gable overhang parameter, hence the overhang under the hip options is grayed out.
                          Now, on to the dutch gable...
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            First look at dutch gable complex roofs:
                            http://design.medeek.com/resources/trussplugin/images/truss_su549_800.jpg
                            After I setup the system for the half hip this one fell out without too much trouble.
                            View model here:
                            3D Warehouse
                            Now it is time to move on to the sheathing and cladding, but first I need to add in some options for battens and cross battens.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.5.2 - 10.04.2019
                              • Added the half hip option for complex roofs within the "Edit Roof Plane" tool/menu.
                              • Added the dutch gable option for complex roofs within the "Edit Roof Plane" tool/menu.
                              • The "Edit Roof Plane" tool has been made non-persistent to further improve stability.
                              (Click on image for animation)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                First look at roof sheathing:
                                http://design.medeek.com/resources/trussplugin/images/truss_su550_800.jpg
                                Roof cladding is a little more involved because of the cladding extension parameter.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  A few more kinks to work out in the sheathing module, but overall it is working better than expected and it wasn't nearly as hard to code as I initially thought it would be.
                                  View model here:
                                  3D Warehouse
                                  Still a bit more work to do with sheathing when the dutch gable option is utilized. As you can tell from the model the sheathing is not tucking under the gable end overhang just yet. I will be addressing this tomorrow.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    The rebuild time on this model takes about 1.5 seconds. That is just with the roof primitive and sheathing.
                                    http://design.medeek.com/resources/trussplugin/images/truss_su551_800.jpg
                                    The question is what will the rebuild time be like for a model/roof this complex when all of the rafters and other accoutrements are included?
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.5.3 - 10.05.2019
                                      • Added sheathing for complex roofs.
                                      • Fixed the sheathing at the gable overhang for dutch gable complex roofs.
                                      http://design.medeek.com/resources/trussplugin/images/truss_su552_800.jpg
                                      As shown in the image the sheathing with a dutch gable roof tucks up under the overhanging gable end.
                                      View model here:
                                      3D Warehouse
                                      With this fix I think we are now 100% with the sheathing. I will begin the cladding next.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I've been thinking about connecting roofs together, for example a gable roof connecting to another building where the roof meets the wall. For this type of scenario it might be useful to have an option for a cutoff end (gable end with no overhang etc... I'm not sure exactly what to call this.
                                        P.S.
                                        It's funny where my thoughts take me when I take a breather from the code, I guess even when I'm on break I'm still contemplating what needs to be done with these plugins. I just realized that I can enable one additional option in addition to all the other options (ie. gable, dutch gable, half hip). I will call this a "CONNECTION". Basically you will be able to connect one roof to another (secondary roof). However, rather than having a separate module for the secondary roof I just realized that with the connection option complex roofs can become secondary roofs, so an additional module is not necessary.
                                        I will need to give this considerably more thought but I think this direction I need to go. There will need to be some options for connection type (another roof, a wall or a roof and a wall). I will need to explore the possibilities, this is going to get interesting.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          If things weren't complicated enough with complex roofs, they just got a lot more complicated.
                                          Rather than having two or three different types of connections I think it makes more sense to sub divide it into two additional options and then a connection is simply a connection. You end up with two additional options: TERMINAL and CONNECTION
                                          With terminal it is very similar to a gable end however the roof just ends, no overhangs, no outlookers etc... This would be used when framing the roof up to a wall that is parallel to the roof edge. Theoretically this same type of roof could be achieved with the CONNECTION option however it would remove the requirement for selecting a primary roof (or solid) to connect to, and just simply end the roof in a squared off fashion.
                                          The CONNECTION option is a bit more interesting. To get the results that we want we need to make this end treatment as general as possible. One could potentially connect to any group or component in the model or to another Medeek complex roof assembly. I will need a tool within a tool which allows the user to select the primary roof/object that they would like to connect to.
                                          1. If the selected group is a Medeek roof assembly then the primary roof will also store that it is being connected to by a secondary roof, and the secondary roof will list the instance name of the primary roof it is connecting to.
                                          2. If the selected group or component (must be a solid) is a non-Medeek roof assembly it will also store and list the instance name of the primary object that the roof is connecting to.
                                          Here are shown a couple of possible connection scenarios:
                                          http://design.medeek.com/resources/trussplugin/images/truss_su554_800.jpg
                                          Connecting to another complex roof at an oblique angle and below the fascia line.
                                          http://design.medeek.com/resources/trussplugin/images/truss_su553_800.jpg
                                          Connecting to a non-Medeek roof (solid group).
                                          To keep this option from completely spiraling out of control we must make the assumption that the only roof planes impacted by the connection will be the two adjacent and orthogonal roof planes that are either side of the connection roof edge (the connecting roof plane technically does not exist). I'm sure there will be users who try to subvert this requirement in certain design situations, so some logic to check this limitations may need to be implemented.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            When you are connecting a roof into an arbitrary solid (ie. walls) you may end up with something like this:
                                            http://design.medeek.com/resources/trussplugin/images/truss_su555_800.jpg
                                            View model here:
                                            3D Warehouse
                                            You will notice I've modified the roof primitive to emphasize the gable overhang. The key takeaway is that a roof connection should be treated like a gable end condition but with a certain amount subtracted away. That way if you do have a situation like the one shown, you will get your rakeboard etc... The trick of course is too make sure the logic is smart enough to identify these potential configurations and then adjust for them.
                                            design.medeek.com
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 75
                                            • 76
                                            • 50 / 76
