    Minimum internal radius cutting bit for ply
    2 Posts 2 Posters 3.3k Views 2 Watching
    • L Online
      Hi, I am designing a lamp. It will be cut from 18mm hoop pine plywood. I am designing the profile but have a question if there are any CNC plywood cutting experts here.
      On the attached drawing I have 2 arrows pointing to the internal radius the blue arrow is a zero rad which is not possible with a cutting bit.The red arrow shows it with a 6mm rad, which I do not like, so the smaller the rad the better. cutting bits can have a minimum of 1.5mm Dia but I am sure that would deflect and break. Long story but I cannot ask the guy who will be doing the cutting as he is not contactable for a week
      What is the smallest recomended bit size to do the job? I know people are going to suggest using lazer but the discolouration caused by the lazer is not doable due to the discolourisation.
      • F Offline
        Futurepast
        Feed rate and cut depth are what is important. It they feed rate is slowed a smaller diameter is possible.
