    Twinmotion is now free
    89 Posts 29 Posters 55.1k Views 29 Watching
      is it possible to change the backgroundsphere to my own equirectangular pano?
      Seems yes πŸ˜‰
      Minute 0.57 second video! Sorry in French... but here the transllation πŸ˜‰
      The key is to use a textured dome for create a "context"
      Step 1 - Load textured examples created by Jesus Carbajal
      Step 2 - Save them inside user Library of Twinmotion
      Step 3 - Launch TwinMotion. Domes are organized bottom of the user Library.
      drag & drop them to the scene
      Step 4 - Select the Dome's texture with the ink-dropper. Like this you open the dock of the materials parameters where you can adjust the texture's position.
      Use these domes as example, for create your own environement, you can replace the texture by another 360Β° images.
      PS Not sure you can with these free version.
        You can find the doms here πŸ˜‰
        But where is the User Library folder on computer inside this TwinMotion version for input these files ...that's the mystery! πŸ˜„
        And make our own tmi another one! πŸ˜›
        Maybe also try with the Library/ Volume/ Sphere Reflexion Probe...
        • jo-keJ
          jo-ke
          thank you.
          I will have a look
          here's a new video
          http://www.zz7.de
            Solution of the localisation Path for the Domes files tmi above so you put them inside!
            "C:\Users\your_user_name\Documents\Twinmotion2019\UserLibrary"
            Thx Tenrev at the Forum Biblio3D πŸ˜„
            Stay the problem : how generate new landscapes 360Β° like the domes above?
            • HornOxxH
              HornOxx
              @pilou said:
              You can find the doms here πŸ˜‰ But where is the User Library folder on computer inside this TwinMotion version for input these files ...that's the mystery! πŸ˜„
              And make our own tmi another one! πŸ˜› ...
              this whole dom process remains a mystery to me. Pilou, where exactly does your link lead to? πŸ˜„ ❓
              never trust a skinny cook
              • jo-keJ
                jo-ke
                I can paste the dome to my model but when I change the texture the old one remains and is someway overlapped to the new one.... Strange...
                Also in the lower parts there is Fog. Now Idea how to erase the fog....
                http://www.zz7.de
                  @HornOox if you scrool inside my above link, you will found these domes used in the tutorial video(s) πŸ˜‰
                  1.Download the textured dome examples created in .tmi format.
                  https://drive.google.com/file/d/1Gm3FlhxLmPtyKDd6qkyj1Ccn0jd8uWxB/view?fbclid=IwAR0_j9y4x9KE-F69q5n_LagVLT0wD2t4CHk66F2Qky7NHbWrdS17mgyCQ2w
                  @Joke : no special problem for me : exactly like the videos ! πŸ˜„
                  Maybe Meteo / Effects/ Pollution are enable for any reasons ?
                    And bingo I have found the trick for made our own "Texture 360Β°" β˜€
                    From this image (or any image of anything) here mine MagicaVoxel image! πŸ˜„
                    https://i.postimg.cc/HkYhm9vp/green-worms.jpg
                    You obtain that! πŸ˜„ Alas (you must make some rotate because here we are just on the seam ! : )
                    So Ink-Dropper/ Scale / Offset for have it on the back! πŸ˜„ (not made here)
                    https://i.postimg.cc/MZ5j378Z/Gif-fond-comp1.gif
                    Vegetable Menu / Materials Menu
                    • Take any texture - Clic "Color Plus" to get the Texture Menu
                    • Apply this texture to the dome! (Drag & Drop)
                    • Click on "Texture" word - load any image
                    • Right Click on the Control Globe that contains the new Texture / Add to User Library
                      The native texture is obviously not destroyed!
                    You get your own personalized "Texture Dome"! The famous".tmi" file! πŸ€“
                    https://i.postimg.cc/0jS5v1Bq/process-dome.jpg
                    Last but not the least : how make the "domes above" (surrely with a sphere Glass Double Face etc...)
                      @Joke
                      About fog! πŸ˜‰
                      • david_hD
                        david_h
                        So. . .I just downloaded the engine. I must say the videos look fun. .. but I hope this doesn't end up giving me a headache. Thea is hard enough for me. . . πŸ’š
                          No headache! It's one of the more friendly interface that you can find! β˜€
                          No need to be a 3D veteran for use it! 😎
                          • david_hD
                            david_h
                            Thanks Pilou. I would think I AM a 3D veteren... . just not a very good one. πŸ’š
                            • david_hD
                              david_h
                              Thank you! That was terrific! I'm going to go thru some Tuts this weekend!
                              Thx
                              D
                              • jo-keJ
                                jo-ke
                                Pilou, your tip worked fantastic. Thank you.
                                I am rendering a new video...
                                http://www.zz7.de
                                  The part about of TwinMotion Take a look at 59.59 minutes! πŸ˜‰
                                    dtrarch
                                    Easy to understand but some of the functions just do not work for me at all?
                                    Could this be the graphic card requirements and what is the min needed?
                                    Info please
                                    Thanks too.
                                    dtr
                                      From https://www.unrealengine.com/en-US/faq
                                      For developing with UE4, we recommend a desktop PC with Windows 7 64-bit or a Mac with Mac OS X 10.9.2 or later, 8 GB RAM and a quad-core Intel or AMD processor, and a DX11 compatible video card. UE4 will run on desktops and laptops below these recommendations, but performance may be limited.
                                      they don't speak about the DX 11 in the FAQ but I suppose that is the same for TwinMotion! πŸ˜‰
                                      • srxS
                                        srx
                                        RTX+Unreal+Twinmotion free with Archicad 23 https://youtu.be/FrNeoe_viyY
                                        www.saurus.rs
                                          dtrarch
                                          Pilou
                                          Thanks for the info.
                                          Time to upgrade my card.
                                          πŸ‘ πŸ‘
                                          dtrarch
                                          • SchuppeS
                                            Schuppe
                                            .....another Video.
                                            I`m not a stop-motion artist, itΒ΄s easy to see. hahaha
                                            But iΒ΄m workin on it πŸ˜„
                                            Rexi in motion
                                            • 3 / 5
