    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Version 2.3.8 - 05.16.2019
      • Fixed a bug with the pitch and area callouts for asymmetric gable rafter roofs.
      • Fixed a bug with the back/rear outlooker length for gable rafter roofs which now allows for a building or roof length that is a non-integer multiple of the rafter spacing.
      • Added the option in the gable rafter roof edit menu to specify a separate front and back overhang length.
      http://design.medeek.com/resources/images/truss_su397_800.jpg
      The issue with the rear outlooker length will also need to be addressed for truss assemblies.
      I should also make the option for the separate front and back overhang length available for trusses as well. Lots of little things as well as big things to do.
      The consensus seems to be that the sheathing should terminate at the sub-fascia and not extend over the fascia, especially if the rafter tail is a plumb cut (fascia is vertical). However, this preference also seems to be highly dependent on the particular application and type of fascia used.
      Here is another interesting detail:
      https://cdnassets.hw.net/b3/45/c1dd531e41f48dfb62b6ff7be58b/0917jlcwildfire-illo-01-rev.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        A few other things to note with regards to fascia and soffit:
        1.) In order to enable soffit and fascia the advanced options must be turned on and the sub-fascia option must also be turned on.
        2.) The consensus appears to put the fascia top flush with the sub-fascia top with the sheathing terminating at the outside edge of the sub-fascia.
        3.) Gutter placement will then be unaffected by the fascia other than be offset by its thickness.
        4.) The soffit will be placed level to the horizontal and extend to the outside edge of the sub-fascia meeting the fascia and to the wall sheathing. Since the plugin is not keeping track of what walls are being used (Medeek, Framer, or a simple solid), there will be a wall sheathing offset parameter that will allow the user to control this offset. I've noticed some details showing the soffit extending to the framing, others to the sheathing and still others to a brick or stucco layer.
        5.) The soffit top surface will abut the underside of the sub-fascia.
        6.) Materials for soffit and fascia will both be user driven/customizable.
        7.) Parameters to include: Soffit thickness, Fascia thickness, Fascia depth.
        8.) I will also be adding in an additional parameter for the roof cladding which allows the user to extend it beyond the sheathing a specified amount (Roof Cladding Extension). This will naturally extend the ridge or hip caps the appropriate amounts as well.
        I realize there are other soffit variations but I will be starting with the flat soffit first and then consider the angled soffit in future developments.
        design.medeek.com
        • medeekM
          medeek
          Version 2.3.9 - 05.17.2019
          • Enabled a roof cladding extension parameter for all hip rafter roofs.
          http://design.medeek.com/resources/images/truss_su398_800.jpg
          The extension is measured inline with the roof plane (not with the horizontal).
          design.medeek.com
          • medeekM
            medeek
            First look at the soffit and fascia (hip roof):
            http://design.medeek.com/resources/images/truss_su399_800.jpg
            Also note the roof cladding extension (3/4") with a 6:12 pitch.
            design.medeek.com
            • medeekM
              medeek
              Version 2.4.0 - 05.19.2019
              • Enabled soffit and fascia for all hip rafter roofs.
              • Fixed a minor bug with the ridge cap extension for asymmetric hip roofs.
              • Enabled custom materials for roof sheathing and roof cladding in the HTML edit menu for all hip rafter roofs.
              http://design.medeek.com/resources/images/truss_su400_800.jpg
              http://design.medeek.com/resources/images/truss_su401_800.jpg
              Custom materials is also enabled for both the soffit and the fascia. Soffit and fascia can only be specified in the edit menu once the roof is created. The current draw menu presents the user with far less parameters and will be updated to a more advanced HTML menu in the future.
              Once I am satisfied with the soffit and fascia with the hip roofs I can then extend it to gable, shed and dutch gable roofs and all other truss roofs.
              View example model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • medeekM
                medeek
                I'm considering adding in drip edge but then again it may be a step too far?
                http://design.medeek.com/resources/images/truss_su402_800.jpg
                If gutter is enabled then the drip edge is barely visible. For estimating purposes I can just calc the perimeter of the roof to get the lineal feet of drip edge. Is it worth the effort?
                design.medeek.com
                • medeekM
                  medeek
                  After some further testing of the roof cladding extension parameter I think it makes more sense to make the extension per the horizontal and not per the roof plane. The problems really only seem to arise when you have an asymmetric roof, in this case the higher pitched roof will project less than the lower pitched roof if the extension is parallel to the roof plane.
                  Thoughts?
                  design.medeek.com
                  • medeekM
                    medeek
                    The two most common drip edges I've seen applied to residential roofs are the right two profiles shown in this image:
                    It would be more light weight to represent these metals as simple edges and faces but then they would Z fight with whatever they are resting on so I guess it is probably better to assign a thickness and model them as a solid instead.
                    So the two options to start will be a L or a D drip edge (not sure why they call it a D). The dimensions will all be customizable like the roof gutters.
                    design.medeek.com
                    • medeekM
                      medeek
                      I've decided to put the drip edge on hold for just a bit and focus on the secondary roof module.
                      There is really two ways to handle this. You can either start with a primary roof and then add secondary roofs that tie into it. Or you can allow the user to pick the building outline (any polygon) and utilize a straight skeleton algorithm to compute the roof planes. There are some pros and cons (limitations) to each method.
                      Obviously with the straight skeleton method one would assume that the fascia lines up all the way around the roof so it doesn't lend itself to secondary roofs like dormers that may be positioned up on the roof.
                      However, the straight skeleton allows for some really complicated scenarios that you just cannot achieve with a secondary roof methodology.
                      A few months ago I was trying to come up with a robust straight skeleton algorithm and somehow it defeated me. This morning I took a slightly different approach and I now think I've finally solved it:
                      Step 1:
                      http://design.medeek.com/resources/trussplugin/images/truss_su406_800.jpg
                      Step 2:
                      http://design.medeek.com/resources/trussplugin/images/truss_su403_800.jpg
                      Step 3:
                      http://design.medeek.com/resources/trussplugin/images/truss_su404_800.jpg
                      Step 4:
                      http://design.medeek.com/resources/trussplugin/images/truss_su405_800.jpg
                      Once I have the roof "solid" I can then easily pull out the edges that represent the hips, ridges, valleys and flying hips. From there it is just a matter of some tedious logic to detect whether to frame a common, hip jack, valley jack or cripple jack (hip/valley jack).
                      Of course the devil is in the details but I now think I have a path forward for complex roofs, this is major breakthrough.
                      design.medeek.com
                      • medeekM
                        medeek
                        I will also need a tool or function that allows the user to toggle specific roof planes from hip to gable or back again.
                        design.medeek.com
                        • medeekM
                          medeek
                          The complex roof algorithm seems to be fairly robust thus far, I haven't been able to break it just yet. However as I am contemplating how to make it so that each roof plane is adjustable (variable pitch) it is quickly becoming apparent that such a feature would become very complicated.
                          The issue really is a situation where you have a particular roof plane that you want to adjust. You then change its pitch (assuming all other pitches are left the same) and the roof gets recalculated. In certain situations that roof plane may then merge with another roof plane. If that happens then one of the two roof planes is absorbed by the other (both pitches must be equal of course).
                          The difficulty seems to arise in the tracking of each roof plane and the custom pitch assigned to it. The number of roof planes can be variable. The ability to edit each roof plane will need to be an "on the fly" sort of tool which allows the user to adjust only one roof plane at a time and then recalc the entire roof to re-determine the shape of the roof and hence how many and where its new roof planes actually are.
                          The easiest way to store this information, in my option. is to maintain the roof solid group (on a separate hidden layer). From this solid the roof planes can quickly be ascertained as well as the outline or footprint of the roof. I'm still thinking this one through as you can probably tell.
                          Initially the roof will be drawn with one overhang and one pitch. Where the edit menu can take it from there is where it potentially becomes quite complicated.
                          Consider a complex roof like the one below:
                          http://design.medeek.com/resources/trussplugin/complex_roof_800.jpg
                          I can see that the framing can be accomplished with some basic rules/logic however non-orthogonal roof outlines will probably require some additional logic.
                          The tool that allows the user to define the footprint or outline of the roof should allow for the selection of a face or allow the user to pick points that then define the closed path of the roof outline. The code required to do this is already within my foundation plugin and will only need some minor modifications to make if work for this module as well.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.4.1 - 05.25.2019
                            • Parameter hightlight (input) color added to General tab of global settings.
                            • Parameter change highlighting enabled for the gable and hip rafter roof edit menus.
                            • Added the indexing parameter for roofs and floors to the General tab of the global settings.
                            http://design.medeek.com/resources/trussplugin/images/truss_su407_800.jpg
                            A few minor items addressed per recent customer requests.
                            design.medeek.com
                            • medeekM
                              medeek
                              Since the hip rafter roof now has soffit and fascia I thought it would be fitting to add the same treatment to the gable roof, however the gable roof is surprisingly more complicated when it comes to soffit and fascia. Take the example shown below:
                              http://design.medeek.com/resources/trussplugin/images/truss_su408_800.jpg
                              A number of questions arise:
                              1.) The sheathing terminates at the sub-fascia (at the eave, per previous discussion) however should it extend out to the gable fascia? or just terminate at the gable sub-fascia as shown?
                              2.) The cladding may need a different treatment even for hip roofs and for gable roofs. Rather than relying on the cladding extension parameter to bring it out over the fascia maybe bring the cladding out to the fascia by default and then the extension parameter brings it beyond the fascia if desired? The cladding extension parameter should also really be per the horizontal rather than per the roof plane due to complications with asymmetric roofs.
                              3.) A number of possible configurations can exist at the corner where the eave and gable soffit meet. Ideas? I don't even know what these variants are called, but I've seen them all. Some architects really don't like the soffit boxes but even these are popular in many regions.
                              File Not Found
                              (diydiva.net)
                              4.) Should the gable fascia terminate as shown or extend beyond the eave fascia (projection). The projected gable fascia seems to be very popular in western Washington.
                              5.) The gutters will naturally be offset if fascia is specified but should I extend the gutters to terminate flush to the gable fascia or leave them so they terminate flush to the gable sub-fascia?
                              These roofs are complicated business. Lots of little details. Even though I'm not an architect or designer I've still got to deal with them all since I'm creating a tool that involves all of these subtle design decisions. Structural elements tend to be a bit simpler in my opinion.
                              design.medeek.com
                              • medeekM
                                medeek
                                I really have no idea if this is the correct way to build a soffit box but here is one possibility:
                                http://design.medeek.com/resources/trussplugin/images/truss_su409_800.jpg
                                A couple things jump out at me:
                                1.) Note the double miter cut of the gable fascia.
                                2.) Note the addition of the two pieces of fascia to create the soffit box.
                                3.) I've shown this soffit box with a 15" return (the minimum return) however one could extend the return further and the eave soffit would then morph into an L shaped configuration. So if this type of soffit configuration is specified I should also provide the user with the ability to set the return length.
                                With gable roofs and their soffit and fascias it looks like I've open yet another can of worms.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Here is a soffit box with an extended return (4"):
                                  http://design.medeek.com/resources/trussplugin/images/truss_su410_800.jpg
                                  Note the L-shaped eave soffit.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.4.2 - 05.27.2019
                                    • Enabled soffit and fascia for gable rafter roofs.
                                    • Enabled a roof cladding extension parameter for gable rafter roofs.
                                    • Enabled custom materials for roof sheathing and roof cladding in the HTML edit menu for gable rafter roofs.
                                    • Added the soffit box extension parameter for gable rafter roofs.
                                    http://design.medeek.com/resources/trussplugin/images/truss_su412_800.jpg
                                    View model here:
                                    3D Warehouse
                                    Note the trimming of the ridgeboard if required.
                                    Currently there is only one way to soffit and fascia the gable roof but if there is enough call for it I can also look at this type of configuration:
                                    http://design.medeek.com/resources/trussplugin/images/truss_su411_800.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      The other configuration I've noticed being used quite a bit locally is the angled soffit:
                                      http://design.medeek.com/resources/trussplugin/images/truss_su413_800.jpg
                                      Personally I think this type of soffit works better where the rafter tails are square cut and not plumb cut otherwise the sub-fascia will probably need to be adjusted (beveled) on its bottom to ensure that the soffit fits correctly.
                                      The one thing to note with this arrangement is that the gable soffit and eave soffit should be coplanar. In order for that to happen the depth of the rafter tails must equal the depth of the rake board (barge rafter). One way to achieve this if the rafters are quite deep is to trim them as shown in the image. An alternative approach is to match the barge rafter with the actual rafters but this will result in a very deep/thick fascia and a heavy look.
                                      I'm just thinking out loud here so correct me if I'm seriously mistaken with any of my musings. The angled soffit is certainly another option that I could add in but I need to make sure there is call for it and that I've got it right.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Now that I have at least one option for soffit and fascia for a gable type roof it makes sense that I extend this functionality to the truss module. However with common trusses I also have the option for various roof returns:
                                        http://design.medeek.com/resources/trussplugin/images/truss_su414_800.jpg
                                        I will need to add some additional logic into the soffit and fascia module so that it can properly handle these more classical roof returns.
                                        If you look at this a little bit further it becomes apparent that you have the gable soffit dropping down into the roof plane of the return. I'm not entirely sure how this would be framed out, but it sure would be helpful to watch a crew installing soffit on a gable overhang where it comes down and meets a hip roof return like the one shown.
                                        The fascia and eave soffit with its extension seem pretty straight forward.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          A quick mock up of a truss roof with hip returns and soffit and fascia:
                                          http://design.medeek.com/resources/trussplugin/images/truss_su415_800.jpg
                                          http://design.medeek.com/resources/trussplugin/images/truss_su416_800.jpg
                                          http://design.medeek.com/resources/trussplugin/images/truss_su417_800.jpg
                                          http://design.medeek.com/resources/trussplugin/images/truss_su418_800.jpg
                                          View model here:
                                          3D Warehouse
                                          I could get all fancy and try to trim the gable soffits so they intersect the hip returns perfectly but looking at it now it doesn't seem to terrible if I just terminate them as I have shown and the carpenter in the field will adjust to suit.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            First look at soffit and fascia applied to a common truss (fink) roof:
                                            http://design.medeek.com/resources/trussplugin/images/truss_su419_800.jpg
                                            If you look closely you can see the roof cladding is extending out over the gutter (0.75"), I'm adding the cladding extension parameter to the advanced options for trusses.
                                            Even though this is working great now for the common truss I still need to add the logic in to handle the hip roof return and full return configurations. I also have the configuration where the back side of the assembly is truncated to allow for abutting next to a wall. This will require yet another soffit and fascia configuration.
                                            design.medeek.com
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 76
                                            • 77
                                            • 59 / 77
