    Move vertices down to surface
    7 Posts 3 Posters 1.2k Views 3 Watching
    • pbacotP Offline
      I want to move the edge vertices down to the surface below (in z direction). So it would be nice if I can select along an edge and have all the vertices of selected edges move to the nearest face below. Is there a plugin that does this? The two surfaces are in different contexts.
      I can do this pretty well one by one manually, but I have a number of them to do. Just wondering.
      • ecatiE Offline
        ecati
        If I understand correctly. If the bottom surface is flat, the Projection plugin. If not, you can use the Sandbox Drape.
        Projection plugin: https://extensions.sketchup.com/en/content/projections-and-guide-tools
        • sdmitchS Offline
          sdmitch
          mod = Sketchup.active_model
          ent = mod.entities
          sel = mod.selection
          SKETCHUP_CONSOLE.clear
          edgs = sel.grep(Sketchup;;Edge)
          if edgs[0]
            vers = edgs.map{|e|e.vertices}.flatten.uniq;
            vecs = []; vrts = []; axis = [0,0,-1]
            for v in vers
              p=v.position;
              h=mod.raytest([p,axis]);
              if h
                vrts << v;
                vecs << p.vector_to(h[0])
            ent.transform_by_vectors(vrts,vecs)
          else
            puts "select edge(s)"
          http://sdmitch.blogspot.com/
          • pbacotP Offline
            when I saw sdmitch on the link I got excited! Let me check it out. Thanks!
            ecati. Thanks! I don't want to copy but just move the vertices, modifying the upper surface edge. No, the lower surface is not flat at all.
            • pbacotP Offline
              sdmitch: It worked awesomely. Thank you! What can I do in return?
              • sdmitchS Offline
                sdmitch
                You're welcome. Nothing.
                • pbacotP Offline
                  Great skilz! Thanks!
