    Help with dialog
    6 Posts 2 Posters 7.4k Views 2 Watching
    • PixeroP
      Pixero
      I need to make a dialog with three dropdown menus where the user can choose from the scenes materials and one input where the default value would be say 1000 mm.
      I have looked at other scripts and tried to create it but I've messed up somewhere as I haven't done my menus in the exact same way as the examples. Could someone please guide me to a working solution?
      Here is the Dialog part of the script:
      	@@first_mat = nil
      	@@second_mat = nil
      	@@third_mat = nil
      	@@distance = nil
      	model = Sketchup.active_model
      	mats = model.materials
      	ent = model.entities
      	sel = model.selection
      	matNames=[]
      	matNstmp=[]
      	mats.each{|m|matNstmp.push(m.display_name)}
      	matNstmp.sort!
      	matNames=matNames+matNstmp
      	matList=matNames.join('|')
      	@@first_mat = matList unless @@first_mat
      	@@second_mat = matList unless @@second_mat
      	@@third_mat = matList unless @@third_mat
      	@@distance = 1000.mm unless @@distance
      	# dialogs
      	info = [matList]
          	prompts = ["Material 1; ", "Material 2; ", "Material 3; ", "Distance; "]
          	results = inputbox(prompts,["", "", "", 1000.mm], [matList, matList, matList, nil],"Settings")
      	results = nil if results and results[0] == ""
        Use this:
        @@first_mat = **matNames**[0] unless @@first_mat @@second_mat = **matNames**[0] unless @@second_mat @@third_mat = **matNames**[0] unless @@third_mat @@distance = 1000.mm unless @@distance
        Then use those in your inputbox's default values etc...
        prompts = ["Material 1: ", "Material 2: ", "Material 3: ", "Distance: "] defaults = [@@first_mat, @@second_mat, @@third_mat, @@distance] pops = [matList, matList, matList, ""] title = "Settings" results = inputbox(prompts, defaults, pops, title)
        After a successful 'result' is returned you need to reset the remembered 'values', thus:
        @@first_mat, @@second_mat, @@third_mat, @@distance = results ###if results
        • PixeroP
          Pixero
          Thank you!
          • PixeroP
            Pixero
            And another one:
            See how the dropdown menu looks in the attached image.
            I have used drop down menus in scripts before without problem but can't find whats wrong here.
            @@axis = "Y" unless @@axis
            prompts = ["Axis; "]
            drops = ["X" '|' "-X" '|' "Y" '|' "-Y" '|' "Z" '|' "-Z"]
            title = "Settings"
            defaults = @@axis
            results = inputbox(prompts, drops, title, defaults)
              It should be
              results = inputbox(prompts, **defaults**, drops, title)
              You have the wrong order... ' defaults' comes second in the list that is passed to the inputbox, AND it must be made as an array - so use defaults = [@@axis] assuming that @@axis is a string- e.g. "X" etc...
              • PixeroP
                Pixero
                Thanks. That worked.
