    Dynamic Component and material
    Scheduled Pinned Locked Moved Dynamic Components
    4 Posts 2 Posters 6.8k Views 2 Watching
      rsekar24
      Hi all.,
      I am creating a Dynamic component of a ply panel with laminates fixed on both sides. (18mmthk x 550 (w)x 700 (h)). I would like to make a report for the cutlist, such that the panel is listed with the description of the two laminates. ( Ie. "Off White laminate - American Walnut) in the material. How to achieve this. any ideas??
      Thanks & Regards
      R.Sekar
        pcmoor
        you can make each face a group, then paint them directly or with formula
        Have the parent reference them with a custom attribute which you can add to your report, so all in same context
          rsekar24
          @pcmoor said:
          Thanks to u, will try and let u know.
            rsekar24
            @rsekar24 said:
            @pcmoor said:
            Hi .,
            i am getting the output like the attached file and not i expected as in single line for the side panel DC as intended in the earlier post.
            Attached herewith the skp file for your review.
            Advice, where i am making error.
            Thanks & Regards.,
            R.Sekar
            Paint.skp
