    Advice for new laptop
    18 Posts 5 Posters 18.5k Views 5 Watching
      Alfani
      @solo said:
      @alfani said:
      Just checked prices for GTX 1070 and they cost around half of my budget, so I need to look for cheaper alternatives 😄
      What rendering software will you be using? is it GPU based?
      Vray for Sketchup and also Archicad and Revit.
        Alfani
        Someone on another forum suggested me this:
        "Basically get the highest processor speed you can afford and a dedicated GPU (Geforce 1060 for example)."
        • soloS
          Amazon.com
          (www.amazon.com)
            Alfani
            @solo said:
            Amazon.com
            (www.amazon.com)
            Woow solo this is great! Only issue is that I can't find it in Greece. Thank you 👍
            • soloS
              Try this:
              The Best Cheap Gaming Laptops We've Tested for 2026
              We've seen the lion's share of the latest GeForce- and Radeon-equipped gaming laptops—and our experts have tested all of the top options in PC Labs. Here's how to get the best machine on a budget.
              PCMAG (www.pcmag.com)
                Alfani
                @solo said:
                Try this:
                This article is exactly what I need! Thanks for all your help 👍
                  Alfani
                  By looking again at my options in Greek market, I found an Asus laptop with AMD R7-2700U processor, 12 GB - DDR4 RAM and AMD Radeon Vega 10 Graphics.
                  Do you see any problems with AMD?
                  • soloS
                    I like AMD CPU's not so much their GPU's, I would avoid the Radeon as most render apps will require Cuda which may be a problem with AMD.
                    • PixeroP
                      Pixero
                      Have you considered a eGPU?
                      I have a laptop with egpu and its great to use for gpu rendering.
                      This is the one I have.
                      https://www.aorus.com/product-detail.php?p=265
                      • N
                        numerobis
                        Just a moment...
                        (www.notebookcheck.net)
                        • K
                          kaas
                          +1 I also use an eGpu so there is gpu power when I need it and when mobile it runs the embedded chip.
                          Using a gtx1080 in a Sonnet Breakaway box. Plus side is: you can upgrade the gpu so maybe buy a less powerful gpu now and upgrade later when you have won the lottery.
                          Make sure you get the Sonnet that has enough power to fit your needs.
                          https://www.sonnettech.com/product/egfx-breakaway-box.html
