Advice for new laptop
To get a decent 3D machine on that budget may be difficult, firstly you will need a machine with a dedicated GPU, a GTX 1070 or better, 16GB ram an SSD drive and possibly either a 2nd SSD or an external HDD. What about screen size? are 15 inches enough?
yes 15" is enough. I will check your suggestions. Actually with my budget, I can only get 256GB SSD and in limited machines, an extra HDD disk with 1 or 2 TB
Just checked prices for GTX 1070 and they cost around half of my budget, so I need to look for cheaper alternatives
What rendering software will you be using? is it GPU based?
Someone on another forum suggested me this:
"Basically get the highest processor speed you can afford and a dedicated GPU (Geforce 1060 for example)." -
Try this:
The Best Cheap Gaming Laptops We've Tested for 2026
We've seen the lion's share of the latest GeForce- and Radeon-equipped gaming laptopsโand our experts have tested all of the top options in PC Labs. Here's how to get the best machine on a budget.
PCMAG (www.pcmag.com)
@solo said:
Try this:
This article is exactly what I need! Thanks for all your help
By looking again at my options in Greek market, I found an Asus laptop with AMD R7-2700U processor, 12 GB - DDR4 RAM and AMD Radeon Vega 10 Graphics.
Do you see any problems with AMD? -
Do you see any problems with AMD?I like AMD CPU's not so much their GPU's, I would avoid the Radeon as most render apps will require Cuda which may be a problem with AMD.
Have you considered a eGPU?
I have a laptop with egpu and its great to use for gpu rendering.
This is the one I have.
https://www.aorus.com/product-detail.php?p=265 -
Expert reviews and news on laptops, smartphones and tech innovations
Notebookcheck provides in depth reviews, technical articles like benchmark comparisons, and news on laptops / notebooks, smartphones, tablets and tech innovations.
Notebookcheck (www.notebookcheck.net)
I have a laptop with egpu and its great to use for gpu rendering.+1 I also use an eGpu so there is gpu power when I need it and when mobile it runs the embedded chip.
Using a gtx1080 in a Sonnet Breakaway box. Plus side is: you can upgrade the gpu so maybe buy a less powerful gpu now and upgrade later when you have won the lottery.
Make sure you get the Sonnet that has enough power to fit your needs.
https://www.sonnettech.com/product/egfx-breakaway-box.html
With your input, this post could be even better ๐
