    [REQ] ON\OFF shadows in all scenes
    8 Posts 3 Posters 1.7k Views 3 Watching
      rv1974
      Ajusting multiple scenes in a large files with shadows turned ON (and saved in scenes) does a lot of harm my mental stability. I dreamed about utility that would toggle shadows in all scenes. The script should memorize the shadows parameters of course.
      Could anybody help with the subject?
      • hdpvH
        hdpv
        I did it but it’s just small script so I’m not sharing.
        Add hidden and show selected elements in all scenes.
        I will post it soon.
        Suforyou
        http://www.sketchupforyou.com
          rv1974
          If 'Add hidden and show selected elements' includes global shadow control it'd be the answer.
          Thank you in advance
          • hdpvH
            hdpv
            It's here : https://sketchucation.com/pluginstore?pln=s4u_OnOff_Shadow
            Suforyou
              rv1974
              Hdpv, you know how to make life easier! I tested- works as expexted πŸ‘
              Thank you so much.
              P.S. One minor nuance: your tool turns shadows on even in scenes where they OFF intentionally(for example, I keep the first scene for work- shadows off+axonometric).
              Could your tool ignore those scenes?
              • hdpvH
                hdpv
                You can UNCHECK "Shadow Settings" properties of the scene in the Scenes tray.
                Suforyou
                  rv1974
                  but it will not make 's4u OnOff Shadow' forget about this scene
                  No problem, it's not so important
                  • Didier BurD
                    Didier Bur
                    @rv1974: you can also use my ScenesTools plugin here: https://extensions.sketchup.com/fr/content/scenes-tools
                    In your case use this option: Display > Scenes Tools > Shadows > Copy-paste from current scene to all scenes.
                    There are many more options for all parameters that make up a scene πŸ˜‰
                    Regards,
                    DB
