    [REQ] ON\OFF shadows in all scenes
    8 Posts 3 Posters 1.6k Views 3 Watching
    • R Do not disturb
      rv1974
      Ajusting multiple scenes in a large files with shadows turned ON (and saved in scenes) does a lot of harm my mental stability. I dreamed about utility that would toggle shadows in all scenes. The script should memorize the shadows parameters of course.
      Could anybody help with the subject?
      • hdpvH Offline
        hdpv
        I did it but it’s just small script so I’m not sharing.
        Add hidden and show selected elements in all scenes.
        I will post it soon.
        Suforyou
        http://www.sketchupforyou.com
        • R Do not disturb
          rv1974
          If 'Add hidden and show selected elements' includes global shadow control it'd be the answer.
          Thank you in advance
          • hdpvH Offline
            hdpv
            It's here : https://sketchucation.com/pluginstore?pln=s4u_OnOff_Shadow
            Suforyou
            • R Do not disturb
              rv1974
              Hdpv, you know how to make life easier! I tested- works as expexted πŸ‘
              Thank you so much.
              P.S. One minor nuance: your tool turns shadows on even in scenes where they OFF intentionally(for example, I keep the first scene for work- shadows off+axonometric).
              Could your tool ignore those scenes?
              • hdpvH Offline
                hdpv
                You can UNCHECK "Shadow Settings" properties of the scene in the Scenes tray.
                Suforyou
                • R Do not disturb
                  rv1974
                  but it will not make 's4u OnOff Shadow' forget about this scene
                  No problem, it's not so important
                  • Didier BurD Offline
                    Didier Bur
                    @rv1974: you can also use my ScenesTools plugin here: https://extensions.sketchup.com/fr/content/scenes-tools
                    In your case use this option: Display > Scenes Tools > Shadows > Copy-paste from current scene to all scenes.
                    There are many more options for all parameters that make up a scene πŸ˜‰
                    Regards,
                    DB
