    Hiding edges in a single component but not entire model
    24 Posts 11 Posters 38.3k Views 11 Watching
      You can open the component and use the Eraser tool to delete the edges or you can select them and hit the Delete key. Keep in mind that edges are required to have faces so deleting edges will remove their associated faces.
        sagarsrinivas45
        i too know that by deleting edges faces will be removed. but by doing your above step it will increase the model size when working on big models so my questions is "IS THERE ANY OTHER WAY, OTHER THAN HIDING OR SMOTHERING THE EDGES" I hope you are clear now. πŸ‘
          If you delete edges, then any reliant faces also delete.
          If you delete any geometry the model's size will reduce.
          Hiding or smoothing edges still leaves those edges there.
          If you have unused components then using Model Info > Statistics > Purge Unused... will reduce the model's size.
          This is by far the most effective way to optimize your model's size...
          If you don't want to 'see' some edges, then hide [or smooth] them and use a Style that has hidden-geometry OFF.
          If you don't want to see some objects [groups/component-instances] then put them on an OFF layer.
          Otherwise make your geometry simpler from the kick-off...
            I'm clear on the fact that deleting edges will delete faces. Hiding or softening edges will make them invisible and allow the faces to remain. The only other option to reducing the number of edges in your model would be to simplify the model. For example, instead of using a circle with 24 sides for a cylinder, maybe use 16 sides. That reduces the number of edges and the file size but also results in a rougher looking model. I hope you are clear now. πŸ‘
            • BoxB Offline
              I'm slightly unsure now. Can I design a pillow in Sketchup that can be used for smothering, could be very handy. I'm writing this in lower case so less people will read it.
              • H Offline
                hygicell
                I have the same kind of problem, on two levels:
                I have downloaded a component from the 3D Warehouse (a heating radiator) on which the edges are not visible, while I want them to be, as the image without edges is blurry
                plus on components and groups I made myself, some edges are visible, some are not or seem smoothened or softened
                please help
                Frank
                  @hygicell said:
                  please help
                  Frank
                  Unhide the edges or unsoften them. If you share the SKP file so we can see exactly what you've got, we can give you more specific answers.
                    LEGOsketcher
                    Is there any smart plugin that hides all edges (not faces) in several components at the same time? I have rather large model made og subgroups with lots of lines. I used to hide in wireframe manually but isn't there a smarter way? There is always on in S πŸ˜„
                    • BoxB Offline
                      Eneroth's Visual Merge might do what you want.
                      https://extensions.sketchup.com/en/content/eneroth-visual-merge
                        LEGOsketcher
                        Thanks, good but which I am trying out atm. The geometry might be too complex though. Can something be done with selection tools only edges in all nested groups or so?
                        • BoxB Offline
                          Burying your question in an old thread that has had more than 20 thousand views in the 7 or so years since it was posted isn't the best way to get a clear answer. Too many old opinions and may people don't bother reading such old threads.
                          Try posting a new thread with all the details of your question and see how you go from there.
                          • PixeroP Offline
                            Pixero
                            I have this script that hides all edges in a selection.
                            Not sure where it came from.
                            HideAllEdges.rb
                              LEGOsketcher
                              Jackpot! Takes a while to process but does exactly what I require it to do. Great help, appreciated.
                              • 2 / 2
