    A decent Sketchup Material Manager
    12 Posts 4 Posters 3.4k Views 4 Watching
    • BoxB Offline
      Would it not be simpler to create a library (sounds like you have created one already) of materials and simply use them on your work rather than remodifying downloaded material all the time.
        Sketchvolution
        I actually have no choice but to have to edit every component I download from 3D Warehouse if I want to keep my "Master Model" clean. Nothing that comes from there fits my organization. Much of what comes from there (if not everything) has useless data, needs to be "adjusted", purged, and have it's materials/textures configured properly for rendering. Regardless of whether or not I have a pre-established library of materials that I can use to substitute what natively comes onto the 3D Warehouse's objects. It all needs adjustments. It's important to understand every step of my process... having a good library is not enough.
        Plus, as an example, consider a tree model... plants in general. Most of them come with textures that are object specific, which means I can't just pick "something preconfigured" from my library and simply "exchange" materials... it just doesn't work. It might be a texture simulating a branch full of leaves, for example. The same applies to a lot of other objects there. And this things need to be "worked out", the very way I so carefully explained previously, for all those reasons I stated.
        It is not that simple.
          rv1974
          Your OCD beats mine easily. 😲
          Renaming components materials in semi-manual way is refined waste of time.
          I use hundreds of proxies (in Max) from over 9000 sources and never had a need in renaming
            Sketchvolution
            Well, we agree it's complete waste of time, and I detest doing that the way it's done, precisely why I'm here. And we are talking about SketchUp models (not Max), which ALL come with embedded Textures, which eventually "are missing" when I upload Jobs for cloud rendering If I just download components and use them as they come. About the "naming thing", the problem frequently is that SketchUp's materials names don't match it's texture file name, and when a certain texture map gets "missing" (If I didn't do what I usually do) it's virtually impossible to spot from which material It is missing due to the complete mess of weird material names and it's unmatching texture files... which all get automatically saved in a random temp folder. And then I get a faulty render. See the problem?
            It's no OCD buddy, my method is a response to direct experience. I just need a better, decent Material Manager! Plus I like things real tidy πŸ˜„
            • Didier BurD Offline
              Didier Bur
              @sketchvolution:
              I have sometimes the same problem as yours with 3DWE components. So I think I can do a plugin that will help you through steps 1 to 5 in a matter of a few clicks.
              I don't promise anything, but I'll try πŸ˜‰
              Regards,
              DB
                Sketchvolution
                @didier bur said:
                @sketchvolution:
                Regards,
                Oh my. Were I surprised (and happy) when I read this! I honestly wasn't expecting replies to this topic anymore... It's been quite a while since I posted it. Simply for the intention, I thank you very much Mr. Bur!
                And just to emphasize my points... I just finished a job in which I had to deal with 19 to 25 "missing assets" when I sent my scenes for cloud rendering. And I was in such a hurry to get things done (due to "deadlines", of course) that I ended up pressing the "fuck it" button... which sometimes work... other times it just backfires when something comes up screwed up in the final render. It pisses me off, because I am so careful and thorough with all that I do to get final result perfect, and still I have to deal with this. It causes problems and wastes time. 3D Warehouse is (no doubt) a blessing for us who use Sketchup, and I am really glad we have it, but the "organization part" of working with it is just too messy! I'm not really complaining about 3D Warehouse stuff... I'd rather have something somewhat "messy" than having nothing, that's for sure. But that's the nature of the models that come from there... they ARE messy.
                Man, do I talk! Anyway, thanks again Didier! I'm glad for your intention!
                  Didier Bur
                  Hi Sketchvolution,
                  Here is the first step to a component organizer that will (I hope) speed up your work.
                  Install it the usual way. After installation, select Toolbars in the Display menu, and tick the "Components Cleaner" checkbox.
                  You'll get a toolbar like this:
                  Click on the Settings icon and then on the Help button to view a quick-start pdf.
                  Let me know what you think, please report bugs and what can be enhanced. πŸ˜‰
                  !["Rename materials" dialog](/uploads/imported_attachments/jdAU_cc_materials.jpg ""Rename materials" dialog")
                  ComponentCleaner_v0.0.1.rbz
                  DB
                    Sketchvolution
                    @didier bur said:
                    Hi Sketchvolution,
                    [attachment=2:3soo1752]<!-- ia2 -->cc_toolbar.jpg<!-- ia2 -->[/attachment:3soo1752]
                    [attachment=1:3soo1752]<!-- ia1 -->cc_materials.jpg<!-- ia1 -->[/attachment:3soo1752]
                    Oh my god 😲 . I can't believe it. You actually really, REALLY did put time to make this happen πŸ˜„ . I can't tell how surprised I am. It might sound a little "over the top", but I am actually very excited after seeing this. I will most definely try the plugin now to feel how it works, and just by the panel's layout look I can tell it must be great!
                    At this very moment I am going through all that process I explained earlier at a job I recently picked, so it is a perfect time to test the plugin. Let's see how this baby works. I'll make a list os "improvement points" if a I find any, also I'll make notes about the functions that work the way they should.
                    I'll bring feedbacks! Thanks man! This is a great thing that you did πŸ˜„ !
                      Didier Bur
                      @ sketchvolution:
                      I just found a bug this morning: don't worry if some of the thumbnails are not found in the panel, this is fixed.
                      DB
                        Sketchvolution
                        @didier bur said:
                        @ sketchvolution:
                        [attachment=0:1lqu2blp]<!-- ia0 -->thumbnailsnotfound.jpg<!-- ia0 -->[/attachment:1lqu2blp]
                        Good afternoon sir!
                        I have tested your plugin and already have some feedbacks to give, though I confess I still need some extra experimenting with it the way it is in its initial stage. And now that you "kicked the ball" I guess I feel like I need to spend some time myself thinking about how I could give you more ideas to make it a great tool.
                        Now I must know how to proceed from here. As I created a document with extensive comments (as topics) about the script, I don't think it would be a good idea to just "throw it all" here, specially because I never did something like this before. What I have is a .RTF document... but I can make it a .DOC file or whatever you feel is best. I could e-mail you it. Or you give me a better idea about how to go on from here so that we do it...
                          Didier Bur
                          You can PM me a doc, or ods, or rtf, or pdf. All these will be just fine πŸ˜‰
                          Regards
                          DB
