    Too Many Section Planes are too foggy. Any suggestion?
    6 Posts 4 Posters 1.3k Views 4 Watching
    • W Offline
      whx5hw
      I do drafting/modeling for an interior designer and, when I need to adjust the section planes, it is a little difficult to navigate around the model to place the section planes at the right spots.
      any way to make section planes more transparent or organize them in a way to see only a handful of them at a time?
      Too Many Section Planes and They are too foggy to navigate around the model. any suggestion?
      I do drafting/modeling for an interior designer and, when I need to adjust the section planes, it is a little difficult to navigate around the model to place the section planes at the right spots. any way to make sec…
      SketchUp Community (forums.sketchup.com)
      Too Many Section Plane Example
      Too Many Section Plane Example 2
      • pbacotP Offline
        Wow that IS a lot of planes. I relate planes to layers and to scenes to be able to see one at a time, but that may not work for you. It looks like you are doing architectural work. I can't imagine how you are making use of soooo many sections. Maybe put several in each of a new set of "section" layers. Then you can turn off most of the section layers to be able to see fewer planes at a time.
        It may be that the sections belong to only a portion of the project that is (already) or could be a discrete component. Placing the related sections inside that component will also help isolate viewing fewer planes at a time.
        • jujuJ Offline
          juju
          Sections Manager
          also consider
          Curic Scene Manager
          • W Offline
            whx5hw
            Yes, I used them for interior elevations.
            However, I learned that I should have put the camera position facing the elevation that I want w/ parallel projection instead of putting section each time....................
            well, well, but
            that is good idea to put a group of section planes in a layer so that i can turn on/off!
            thank you for your input!
            • W Offline
              whx5hw
              that's great recommendation. Thank you!
              @juju said:
              Sections Manager
              also consider
              Curic Scene Manager
              • brettsichellodesignB Offline
                brettsichellodesign
                When I do interior elevations in my models, I set it up in a new sketchup file and reference in my 'base' model. This way i don't have a million scenes or section lines in my main construction model.
