    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 0.9.9j - 11.13.2018
      • Added the following corner treatments: 3 Stud Solid, 4 Stud Solid, 3 Stud Block, 4 Stud Block, U-Cal
      • Enabled a parameter in the General tab of the global settings to toggle the labeling of groups.
      http://design.medeek.com/resources/images/wall_su275_800.jpg
      I also addressed some minor issues with the way blocking and insulation interact with the corner treatments. Its seems I have that ironed out now and much less likely to generate geometry that clashes.
      http://design.medeek.com/resources/images/wall_su277_800.jpg
      I don't know how commonly the U-shape California Corner (U-Cal) is used (shown above) but I really like the fact that it offers more nailing surface for ext. trim and siding. I've had a few requests for it as well, so being as it was not too hard to include I added it in. There are now seven possible corner treatments for walls, the other two are California or None.
      http://design.medeek.com/resources/images/wall_su274_800.jpg
      I typically like to name all of the groups I create within the assemblies however there may be some who do not want this behaviour and so I have made it optional.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 0.9.9k - 11.15.2018
        • Added the ability to import materials directly from the model within the Custom Material Libary/Manager in the global settings.
        • Provided an additional parameter in the Wall Corners tab of the global settings for setting the thickness of corner blocking (3 and 4 Stud Block corner treatment only).
        http://design.medeek.com/resources/images/wall_su278_800.jpg
        With this latest update the tutorial on the Material Manager is somewhat out-of-date/obsolete. However the basic functionality has not changed, I've really only added one additional action.
        http://design.medeek.com/resources/images/wall_su279_800.jpg
        The ability to customize the blocking on these corner treatments was per a request from one of our Australian clients. I've added a tooltip in the global settings to more fully explain the usage of this parameter.
        Now back to the big items on the list.
        design.medeek.com
        • medeekM
          medeek
          Some of you may have noticed the difference in the way materials are handled between the garage doors and man doors. The method being used in the garage door module is the new and improved method. I will be updating both the man door module and the window module to this new system which incorporates the materials in the Custom Material Library.
          Also at some point I need to switch the draw door, draw window and draw garage door menus to HTML. As always, never a dull moment and way too much to do.
          design.medeek.com
          • medeekM
            medeek
            Per customer request the available sizes of Wide Flange Steel Beams will be increased to the following:
            W8x10
            W8x13
            W8x15
            W8x18
            W8x21
            W10x12
            W10x15
            W10x17
            W10x19
            W12x14
            W12x16
            W12x19
            W12x22
            W14x22
            W14x26
            W14x30
            W14x34
            W16x26
            W16x31
            W16x36
            W16x40
            W18x35
            W18x40
            W18x46
            W18x50
            W21x44
            W21x50
            W21x57
            W21x62
            W24x55
            W24x62
            W24x68
            W24x76
            design.medeek.com
            • medeekM
              medeek
              Version 0.9.9i - 11.10.2018
              • Added angle iron (L) beams to the beam module.
              • Added fillet radiuses to wide flange (W) and universal (UB) beams.
              http://design.medeek.com/resources/images/wall_su272_800.jpg
              Nine different beam types with two series of wide flange beams (W and UB).
              http://design.medeek.com/resources/images/wall_su273_800.jpg
              Aside from residential structures one could also use the beam module to create various structural steel assemblies, however that is not really the purpose or target audience for this module.
              I added the fillets to the wide flange profiles per customer requests. The primary reason for including this information it to better predict and check bolt patterns that are on the web of the beam(s). Fillet radiuses are per the various standards.
              I haven't take the time yet to add in the few hundred standard sizes from my steel manual but as time allows I will continue to populate these fields. Also if there is specific requests for sizes or series of beam types I will accommodate those requests.
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • medeekM
                medeek
                I been thinking about putting on a weekly one hour webinar where I can demonstrate the latest features of the plugin and then take additional questions from the audience. Would there be any interest in this?
                design.medeek.com
                • medeekM
                  medeek
                  Version 0.9.9l - 11.16.2018
                  • Added an option to include 2D wall geometry in 3D modes (Framing, No Framing, CMU).
                  • Added an additional layer for 2D geometry.
                  • Added customizable colors for labels, 2D wall geometry, and 2D features (windows, doors, columns etc...)
                  http://design.medeek.com/resources/images/wall_su280_800.jpg
                  http://design.medeek.com/resources/images/wall_su281_800.jpg
                  http://design.medeek.com/resources/images/wall_su282_800.jpg
                  The custom colors for the labels, and 2D geometry is per a discussion with a client today. Hopefully this upgrade will help facilitate bringing the 2D geometry into layout for creating floor plans.
                  design.medeek.com
                  • medeekM
                    medeek
                    On a related note I just noticed John Brock's new book has been released:
                    Amazon.com
                    (www.amazon.com)
                    I think this will be a seminal work on incorporating SketchUp into the residential design process. I've already gone ahead and pre-ordered my copy.
                    design.medeek.com
                    • medeekM
                      medeek
                      First look at the output of the Stair Module:
                      http://design.medeek.com/resources/images/wall_su283_800.jpg
                      Note, that only straight runs of stairs will be available for now, however it is possible to create L and U shaped staircases just by combining straight runs as shown and framing in a landing.
                      View model here:
                      3D Warehouse
                      I will probably need one more day to fine tune it completely and finish adding in the hanger board and landing tread advanced options.
                      Future advanced options will be landings, hand rails, skirt boards etc...
                      The stringer algorithm is really the core of the module and drives everything else. The logic was not nearly as complex as I initially thought it might be, regardless it was a blast to work through it and turn the math into reality.
                      http://design.medeek.com/resources/images/wall_su284_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Had to jump through a few hoops to get the materials/textures to all work out correctly but I'm pretty pleased with the way its coming together:
                        http://design.medeek.com/resources/images/wall_su285_800.jpg
                        LVL stringers with timber (wood grain) risers and treads.
                        design.medeek.com
                        • pbacotP
                          Wow! Looks great!
                          • medeekM
                            medeek
                            Version 0.9.9m - 11.21.2018
                            • Added the stair module (straight run only) with the following advanced options: thrust block, landing tread, hanger board.
                            Hanger Board and Landing Tread:
                            http://design.medeek.com/resources/images/wall_su287_800.jpg
                            Landing Tread:
                            http://design.medeek.com/resources/images/wall_su286_800.jpg
                            There are quite a few options with the stair module so I will need to make another tutorial video explaining the usage of these parameters. I have provided tool tips next to each option in the draw and edit menus to help explain what each is.
                            A few items with the draw tool:
                            1.) First select the top of the stairs location and then select a point for the bottom of the stairs. The preview wireframe should be fairly explanatory as to the location and geometry of the stairs that will be created.
                            2.) Once the first point is selected you can lock to an orthogonal axis (0, 45, 90, 135 deg.) or direction by repeatedly clicking the "Ctrl" key.
                            3.) Once the first point is selected you can also toggle the placement of the stairs by repeatedly clicking the down arrow. The justification is: Center, Left, or Right.
                            4.) As with the other HTML draw menus, you update/change your parameters and then click the Update button to make them live. You can leave the menu open while drawing your stairs. Hitting the space bar will exit the tool, hitting the ESC key will reset the tool.
                            With the draw and edit menus you will notice that for the tread and riser material you also have the option of utilizing materials found in your custom library. The stringer material is limited to certain specific material types (at least for now).
                            This is a completely new module so I expect there may be some minor issues and additional features that will be requested.
                            I still need to create the global settings tab for the stairs so that default parameters can be set for each option. However, it is not critical to the function of the module.
                            design.medeek.com
                            • medeekM
                              medeek
                              Honestly, another plugin with plugin on this one. I could have added it to the Truss Plugin or even separated it out as its own plugin, for now though it will live within the Wall Plugin. The code base is logically separated from the rest of the plugin so moving it would be a non-issue if the time comes.
                              I think you use this module once and you will never go back to manually creating stairs or laying out stringers again. I know I certainly won't. The automation afforded by the API is stroke of genius, with it almost anything can be created. At some point I really want to try out my artificial life experiment that I've been mulling about for a while now.
                              design.medeek.com
                              • medeekM
                                medeek
                                After some excellent feedback this morning I am considering adding in additional options for side spacers, gypsum gap, and skirt boards.
                                Everything is fairly straight forward except for the skirt boards. The question arises on how to best terminate the skirt, see image below:
                                http://design.medeek.com/resources/images/wall_su288_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I'm not sure if my scribbling is readable but the bottom diagrams try to explain possible configurations and parameters for the skirt board(s):
                                  http://design.medeek.com/resources/wallplugin/STAIR_SKIRT_BOARDS_800.jpg
                                  I think I can reduce the skirt board configuration down to three parameters:
                                  • Terminal Height Top
                                  • Terminal Length Top
                                  • Terminal Height Bottom
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    The diagrams were not very legible so I created a few details to explain the skirt board end configurations:
                                    http://design.medeek.com/resources/images/wall_su289_800.jpg
                                    http://design.medeek.com/resources/images/wall_su290_800.jpg
                                    http://design.medeek.com/resources/images/wall_su291_800.jpg
                                    http://design.medeek.com/resources/images/wall_su292_800.jpg
                                    If these terminations look good I will begin adding in the logic to create them.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Some feedback on the other forum with regards to additional height requirements if a finished floor is installed has introduced some complications. I have given this some extra thought and my observations are thus:
                                      1.) Where wall-to-wall carpet is being installed the way I have it laid out seems to be correct.
                                      2.) The first point you select to position the stairs is the "Finished Floor" height. So if you need an extra 3/4" for a tile or wood flooring you would select a point that is 3/4" higher than the sub-floor. However, if the skirt boards are supposed to be installed prior to the final flooring then this would not be quite correct since they (their horizontal cut) would need drop 3/4" so that they meet the top landings subfloor.
                                      3.) Similar sort of issue at the bottom of the stairs but slightly different. In this case the stringers will rest on the sub-floor, the bottom tread needs an extra 3/4" of rise, and the skirt boards will probably rest on the sub-floor/slab as well.
                                      Question: Will the skirt boards always rest on the sub-floor or should they rest on the finished floor?
                                      Conclusion: I need to add two extra parameters to the module to account for an additional thickness due to finished floors being installed. Since the finished floor on each level may be a different height (or carpet) we need a separate parameter for top and bottom. If I include a finished floor offset, the correct way to select the points for the stairs would be sub-floor to sub-floor.
                                      • FF Offset Top (default to zero or 3/4"?)
                                      • FF Offset Bottom (default to zero or 3/4"?)
                                      P.S.
                                      In addition to the three parameters for the skirt boards mentions above:
                                      I will also need to include an offset parameter for the skirt boards since we can't be sure that the designer will want to install the skirt board directly onto the sub-floor (it might rest on the finished floor). Actually these parameters should be simple YES or NO parameters (with the offset equal to the finished floor offset from the parameters above) but there may exist a situation where the skirt board may be slightly lifted off of the finish floor so they each need to have a dimension associated with them.
                                      • (Skirt) FF Offset Top (default to zero)
                                      • (Skirt) FF Offset Bottom (default to zero)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        The highlighted yellow areas are the new additions to the stair menus (draw/edit):
                                        http://design.medeek.com/resources/images/wall_su293_800.jpg
                                        design.medeek.com
                                          yes Shemas are indispensable when you have such list of item! 😄
                                          • medeekM
                                            medeek
                                            Here is a situation where the finished floor is 2" off of the bottom sub-floor (slab):
                                            http://design.medeek.com/resources/images/wall_su294_800.jpg
                                            Note that the riser heights are correct and that the bottom riser has an additional 2" added to its height. The question I have is what to do with the riser board itself on this bottom tread?
                                            I've shown it in the configuration where the finished floor can be applied underneath the riser board however is it more common just to extend the riser board to the bottom of the stringer so that it rests on the sub-floor or slab?
                                            design.medeek.com
