    Repeat last command
    7 Posts 7 Posters 23.0k Views 7 Watching
      alz
      A simple one from Maya -- it repeats what you last did (whatever that may be). It was very handy at times.
      (This could probably be an easy Ruby script to make)
      • P
        pav_3j
        yeah that would be pretty useful, i use that function a lot in maya and autoCAD.
        good shout
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • I
          icepam
          absolutely - been looking for that too. repeat last command is a wonderful tool, i use it a lot in coreldraw, e.g. CTRL-R
          the way it works in coreldraw is for example if you duplicate an element then move it, then adjust it a bit, it will remember the offset, so tapping CTRL-R will repeat the duplication, with the same distance.
          the trick is to only save the state of the change after a second or two it has been done, to make sure the command repeats relative to the original and not just the fine-tuning.
            mirjman
            this exists as a double click for most things, like offset and push pull, just double click the next surface and it remembers your offset. for moving things, usually your cursor will snap at the previously entered dimension the next time you draw.
            • Alan FraserA
              Alan Fraser
              The CorelDRAW function works very well for dynamically producing arrays too. For instance, you don't always know how many repeats (of fixed spacing) it's going to take to get from A to B, so typing something into the VCB is just guesswork. It's so much easier to just keep your fingers down on Ctrl+R until you get there.
              3D Figures
              • ArisA
                Aris
                10 years later and still no repeat command?
                Is there any chance somebody might spend some time and make it?
                Rhino has it as well and once you get used to it it's verrry handy!!!
                Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                • N
                  numerobis
                  Did you try this?
                  https://sketchucation.com/forums/viewtopic.php?f=323&t=16751
