    Applying color to circles?
    4 Posts 3 Posters 5.2k Views 3 Watching
      tomot
      the following code draws 4 circles:
      mod  = Sketchup.active_model
      				ents = mod.active_entities
      				sel  = mod.selection
      				face = sel.grep(Sketchup;;Face)[0]
      				locations=[@pt1,@pt2,@pt3,@pt4]
      				locations.each{|loc| @pt1=loc
      				ents.add_circle(@pt1, @vec3, @dia, 24)
      What code do I need to apply a single color to each circle?
      I'm looking at http://ruby.sketchup.com/Sketchup/Color.html for inspiration,
      but I'm not able to make the code work! πŸ˜’
      color=Sketchup;;Color.new(163,204,204)
      TIA!
      my plugins
      tomot
      • Dan RathbunD Offline
        Dan Rathbun
        In order to see colored materials for faces, the rendering options (style) must be set to either "shaded" or "shaded with textures". See the RenderingOptions class:
        http://ruby.sketchup.com/Sketchup/RenderingOptions.html
        IF you are painting the circle's edges, then in order to see the edges colored, the EdgeColorMode by be set to "ByMaterial" rather than "AllTheSame" (black).
        I'm not here much anymore.
          tomot
          Yikes! I should have been more descriptive.
          I'm trying provide a color to the faces of those 4 circles.
          my plugins
          tomot
            Your current 'circle' code only draws some edges [all be it that they are in the form of circles].
            Use e.g.
            edges=ents.add_circle(@pt1, @vec3, @dia, 24)
            Then make a face for one of those edges...
            ents.find_faces(edges[0]) face=edges[0].faces[0]
            Then add a material to the 'face'...
            Of course this is very simplistic...
            e.g. if your circles might overlap etc not all edges might get a face, so then you probably need to make each circle/face inside its own group in turn, at least until you have finished making/painting it etc, after which exploding the temp-group can put the faces back into the desired entities-context...
