    Rings
    32 Posts 10 Posters 10.6k Views 10 Watching
    • cheddaC Offline
      chedda
      Thanks Majid , Mike & Maxwell.
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
        Majid has produced a great product, great things can come from those great models. That is one fine render too.
        My two pence worth, Twilight render.
        Quick.
        • sfto1S Offline
          sfto1
          I downloaded the file and have tried rendering in Thea4SU 1.5 and regardless of how I try and light the scene, I only get a black imgae.
          Is it possible to render in 1.5 or what am I doing wrong?
            Simlab Composer lite πŸ˜‰
            • sfto1S Offline
              sfto1
              I needed to tweak materials for some reason. I did not have a good diamond material so I used clear glass. The rings are sitting on a rough rubber matt. The silver material was switched with Chromium. I could not get the silver to work.
              This is done in Thea4SU 1.5 AO
              Thanks for the Model Majid! and the inspiration 😎
              • majidM Offline
                majid
                Oh mates... I was out for a while and am now back and really happy seeing all these great redults you have achieved and shared.... thank you mates.... You are pushing me forward to share some more ring models i'e prepared...
                  Thanks for the opportunity to render your great model.
                  V8 version attached as I missed the earlier comment about save versions.
                  Ring V8.skp
                    measuredmove
                    Render: Brighter3D and tweaked in Photo Director
                    Thanks for providing SU file, majid, its interesting to see the output possible from various renderers. I hope that more people will use their renderer of choice and post the results.
                    Preset Effects...
                    Black White-Warm
                    Skin Tone-White
                    Golden Harvest
                    My 3D Catalogue
                    https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                    SU8/Brighter3D/Gimp/SimLab Composer
                      Can you put an image of the inside folder inside before the Unzip ?
                      • majidM Offline
                        majid
                        Please use winrar to unzip files after removing the ".rb" from the first file
                        There is a size limitation of 5 MB so I had to divide it, .. Here is the file: https://files.fm/u/as7mgx4q
                        • majidM Offline
                          majid
                          Another model and render....
                          I had to add rb extension letting me to upload the zipped file parts...
                          Also to keep he file size a bit low I used a component to create the second ring, one may explode and smooth inner part.
                          remove the rb from the file name and put all two files in a single folder and unzip please
                            gio
                            Tell me more about it, please...
                            What for do you use it?
                            Does it render??!?
                            Gio
                              No problem! πŸ’š
                              "Lite"
                              Free Maxi Full HD 1920 *1080 sufficient for hobbyist or enthousiasts! πŸ˜„
                              Anything! It can reload quasi any 3D formats and mixes them! β˜€
                              Does it render??!?
                              Of course yes! πŸ˜‰
                              It can also rustic modelise if you want! Boolean Primitives, wires, extrusion , sweep, etc... πŸ˜„
                              (it's not made for that)
                              But as you have yet SketchUp...totally compatible! πŸ€“
                              Real Time, Classical, Only CPU !
                              Any styles! Like Keyshot for the easy use! πŸ˜„
                              Go there and enlarge the images! πŸ˜„
                              Art if you want! πŸ˜„
                              The only limite is your imagination! πŸ˜„
                              • 2 / 2
