    20 Reasons for SketchUp artists to consider Blender
    144 Posts 27 Posters 86.3k Views 27 Watching
      rv1974
      Sorry but my impression is that this stage architecturalmodelling in Blender is a refined torture. The more Blender promos I see , the more I appreciate SU existance (with all its bottle necks).
      • chippwaltersC Offline
        chippwalters
        I have not shown the Architectural addons for Blender, which make things much simpler. Also, Blender's modifiers can cut through a solid wall, whereas SketchUp can only cut through a surface. This becomes most problematic in SU when trying to insert doors and window components but is a breeze in Blender.
        For now I'm focusing on just the basics. I use SketchUp for much more than architectural 3D and so I don't require as much from Blender in terms of architectural prowess. Still, you should look at some of the amazing Architectural addons for Blender. They can do a lot!
        Here's a new tutorial on rendering inside of Blender with Cycles, a free non-biased renderer like Thea.
        Currently working with Cross-Reality technologies
          rv1974
          I thought I'll be the one screaming the king is naked πŸ˜„
            Glenn at home
            I really have to agree with this statement in regards to architectural modeling. The archimesh tool set video seemed very cumbersome and laborious. Now for general 3d modeling Blender is a GREAT option. Still loving these videos.
              chippwalters
              New tutorial on Smoothing meshes in Blender. Compares with how SketchUp does it.
                chippwalters
                A primary reason for switching from SketchUp to Blender is that SketchUp (in 2018) still cannot do bevels!
                Even with Fredo's amazing plugin, it still doesn't work-- and it's not Fredo's fault as he's told me it's about how the engine architecture in SketchUp works. UGH!
                Blender does magnificent bevels and the bevel modifier is just fabulous!!! Watch to see!
                  chippwalters
                  HDRI lighting is incredibly easy to do in Blender with the free HDRI Lighting Setup addon. Check it out:
                    chippwalters
                    All about how to use materials in your Blender scene. In many ways, Blender is similar to SketchUp with regard to how it handles materials.
                    • CarolineJC Offline
                      CarolineJ
                      Thanks for the video tutorials, helpful
                        chippwalters
                        The case for modifiers in SketchUp.
                        Now that Fredo has teased us with an amazing partial-modifier version of FredoBevel,
                        --I'd like to make a case for modifiers in SketchUp. I've been using them for awhile in Blender and they allow one to create amazing geometry fast, PLUS they also allow for design decisions to be made and fine-tuned later, which is always good.
                        In SketchUp terms, a modifier is something that happens at a group or component level. Adding color to a group or component could be seen as a modifier. You can change a groups color at anytime without regard to the changes in the underlying geometry.
                        Let's take a look at an example:
                        Consider this corridor
                        https://lh3.googleusercontent.com/-sHGqdy2y6pg/W3VU0g8ErfI/AAAAAAAAZGs/HDQOQWx0YS0h6K4KK2eZH99YvVJSMjkqgCL0BGAYYCw/h1080/2018-08-16.png
                        https://lh3.googleusercontent.com/-qFC5Kbra-2c/W3VfB2oKxbI/AAAAAAAAZHA/oI8nWPk91cMlYsFZwqHJtLjJpGS2jsYvQCL0BGAYYCw/h1080/2018-08-16.png
                        Here is the geometry without all the reflections (and no handrails either, they were added later-- using modifiers of course...one polyline for all the handrails on the bottom and one polyline for all the handrails on the ceiling.)
                        https://lh3.googleusercontent.com/-rXQkUQItN8U/W3Uzwd_4i9I/AAAAAAAAZGQ/4isVbPgO0oYUAz4Lc_IGWD4fX1LzoaCZACL0BGAYYCw/h494/2018-08-16.png
                        https://lh3.googleusercontent.com/--BvItZnXctI/W3Uz0p3n-EI/AAAAAAAAZGQ/Wj1ldMMAqr4a_SHSBXOH9R9PG2hoXIJyACL0BGAYYCw/h696/2018-08-16.png
                        Now here's the geometry that created the corridor:
                        https://lh3.googleusercontent.com/-DlB16AKuYoQ/W3U0SCfGNmI/AAAAAAAAZGc/jlSLz5fv-xAjpsVK3UzMtSK8AZuLhvwiQCL0BGAYYCw/h800/2018-08-16.png
                        1. Opened ended cube
                        2. Same cube, just a tad larger as a boolean cutter for the wall
                        3. Overhead polygon for lighting
                        4. Rectangle polygon for floor
                        5. Wall and bottom
                        Only 12 polygons, and 2 polylines for the handrails!
                        So, how to get to here from there?
                        These are the modifiers being used:
                        1. SOLIDIFY This modifier takes polygons and extrudes them making them thicker or thinner. It was used on ALL of the objects above (other than #2, the Boolean Difference) to give them thickness.
                        2. BEVEL This modifier was used on #1 to create the camfers, then again on #1 to add more fillets to the chamfre corners. It was also used on #5 to create the round interior and exterior. Because it was applied before the Solidify on #5 both the inside and outside were automatically bevelled.
                        3. MIRROR Selective mirroring and grouping was used on virtually all the objects in order to create symmetrical versions of everything.
                        4. ARRAY The Array modifier was also used to create multiple corridors and stack them together end to end (not shown in picture).
                        The advantage of doing all of this, is I only need to edit the 5 items shown in Green to adjust the sizes, dimensions and design of this corridor.
                        While this is an extreme example, it does demonstrate the power of modifiers.
                        It would be great if SU would add a modifier stack and let plugin developers create modifiers for objects.
                          Personnal BirthDay's Card designed & handcrafted by Syd M itself that is so chic! πŸ˜‰
                          This page is a pleasure for the eyes! β˜€
                            chippwalters
                            For those interested in how to model in Blender, I've created some very short tutes on Intagram:
                            https://www.instagram.com/p/BnnsDb0HODL/?utm_source=ig_web_copy_link
                            There's also a copy over on ba Tips and Tricks:
                            https://blenderartists.org/t/big-little-tips/1126276
                              chippwalters
                              Yes, Syd is a special guy. We've known each other over 40 years now and have worked on a number of projects together. He is such an incredible talent and an even nicer guy in person!
                                chippwalters
                                New video on using the GroupsPro addon to help work on different workplanes.
                                  chippwalters
                                  masterxeon1001 showed me some very interesting ways to create dynamic objects in Blender today and I just had to try it out. Cool beans!
                                  • Bryan KB Offline
                                    Excellent posts.
                                      chippwalters
                                      Quiet lately as I've taken on an interesting plugin project for Blender.
                                      As many of you may know, Blender doesn't really have a component system like SketchUp. That said, Blender's booleans are much more robust and combined with it's modifiers, it can create a pretty solid kitbashing system. In fact, boolean modeling which heretofore has only been seen in NURBS, is possible (with caveats) in Blender.
                                      To that end, I've partnered with some interesting folks and spearheaded a design for a pretty cool kitbashing tool called KIT OPS. KIT OPS could be used to create doors, windows and all sorts of boolean modifier geometry, but right now we're just doing tech INSERTS (KIT OPS INSERTS = SU COMPONENTS).
                                      One particular neat thing about KIT OPS, is it cuts through an entire object. So, if you're inserting a window or door through a wall, it cuts completely through, unlike SketchUp which only cuts through the first surface, requiring you to manually cut the rest. This also results in KIT OPS having a non-destructive workflow, which makes for a tremendous amount of iterative designs.
                                      Anyway, if you're interested, here's a video explaining it. BTW, the renders in the video were done at 15 sec/frame in Blender 2.8 EEVEE at 4K resolution! FWIW, KIT OPS works in 2.79 not 2.8, but once the plugin API is locked down, we'll do the port. This product should be out this week. I'll post here when it's released, just in case anyone is interested.
                                        A cool one! Bravo! 😎
                                          chippwalters
                                          KIT OPS finally released!
                                          https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/KITOPS/ko-hyper.jpg
                                          Hey everyone, we just released KIT OPS and if you're interested in non-destructive, hyperdetailed Kitbashing you should check it out at https://kit-ops.com
                                            rv1974
                                            What Ops stands for?
                                            • 4 / 8
