    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 0.7.4 - 05.29.2018
      • Fixed a bug with the wall polyline tool so that the wall line will snap to the X or Y axis.
      • Added ZIP Systems(c) 7/16" and 1/2" wall sheathing materials to the sheathing tab of the global settings.
      • Added the Z Height option to the wall creation tools. The Z height parameter and option to enable this feature are found in the walls tab of the global settings.
      • Created icons and added toolbars for the Simpson Strong-Wall module and the Columns module, both of which are still under construction.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I really like Huber Engineeered Woods various sheathing products.
        I've added in the sheathing material option for their 7/16 and 1/2 sheathing products:
        http://design.medeek.com/resources/images/wall_su85_800.jpg
        The exterior face has the branded face as shown and the rest of the group (solid) is the OSB texture.
        This will be rolled into the next release, version 0.7.4.
        Densglass will be included in Version 0.7.5:
        http://design.medeek.com/resources/images/wall_su86_800.jpg
        This sheathing product is more commonly used on commercial projects.
        design.medeek.com
        • medeekM
          medeek
          Just when I think I'm starting to figure this thing out it gets a little more complicated.
          Take for instance the wall below with the exterior stone wainscoting:
          https://apocbyelena.com/wp-content/uploads/2017/11/Image-Of-Stone-Wainscot.jpg
          Typically we see stone or brick with a siding or stucco product above it.
          So instead of a single type of cladding and cladding thickness on the wall we might have two different types on the same wall panel.
          The brick or stone might be up to the windows or even somewhere mid height as shown below:
          http://design.medeek.com/resources/images/wall_su87_800.jpg
          Any thoughts on this type of construction, preferences or further complicating factors?
          I think I basically need to allow for more complicated cladding scenarios.
          With brick you often see a rowlock course at the transition:
          http://www.onland.info/images/brickrowlocksect.png
          design.medeek.com
          • medeekM
            medeek
            Here is a good example of a stucco structure with a cultured stone wainscot:
            http://1.bp.blogspot.com/_Bb7dbJJWffU/TBqvvNS8VbI/AAAAAAAAAVg/8byco5ikPFg/s1600/CIMG0911.JPG
            Notice the stucco trim just above the wainscoting and then the ledge of stone that projects beyond the wainscoting just below it.
            The additional parameters for a two cladding exterior system (wainscoting) would be:
            Exterior Wall Wainscoting: YES/NO
            Wainscoting Thickness: in./mm
            Wainscoting Air Gap: in./mm
            Wainscoting Corners: Flush/Lap/Miter/Return
            Wainscoting Material: Brick/Culture Stone etc...
            Wainscoting Height: in./mm
            Wainscoting Ledge/Trim: YES/NO
            Ledge Height: in./mm
            Ledge Depth: in./mm
            Also in the Trim Tab another couple of parameters for the Exterior Trim option above the wainscoting:
            Wainscoting Trim: YES/NO
            Wainscoting Trim Width: in./mm
            Also notice how the stucco trim around the window and doors meets the wainscoting trim and terminates there.
            Why can't you designers and architects keep things simple, I'm going to have to jump through some hoops to code all of this. πŸ˜„
            design.medeek.com
            • medeekM
              medeek
              I've already rolled out two revisions since the initial beta release. Please download, uninstall the older version of the plugin and then install the most current version.
              I've seen some issues with corrupt installations where a newer version is installed on an older version. You need to uninstall the plugin first before upgrading, that is the safe bet.
              Also please check the changelog so you are aware of the updates, even though I do post each update on the board:
              404 - File or directory not found.
              (design.medeek.com)
              I am still noticing a lot of people sending in comments that they are unable to get materials applied when they have not enabled the auto material assignment in the materials tab of the global settings.
              I think what I am going to do is have the plugin set this particular setting to "ON" as the initial default behavior rather than "OFF". I will make this change live with the next release.
              design.medeek.com
              • Bob JamesB
                Bob James
                Is the current version in the download at:
                (design.medeek.com)
                • medeekM
                  medeek
                  (design.medeek.com)
                  Correct. Version 0.7.4
                  I will probably roll another rev. tonight once I wrap up the the work on the tee intersection algorithm.
                  design.medeek.com
                  • medeekM
                    medeek
                    When you delete walls the cutouts on the the top plates are left as you can see in the image below, but a rebuild of the wall will heal those unnecessary cutouts:
                    (design.medeek.com)
                    Please keep sending in your bugs and feature requests. I am going to keep working on this plugin full time as long as the SU community continues to support me in this endeavor.
                    My goal is to have a robust, flexible and full featured architectural design tool that a lot of the SU designers and even DIY'ers can quickly pick up and use.
                    I am trying to figure out some sort of way that I could offer this at a drastically reduced price or even free so that anyone could take advantage of it but at the same time maintaining enough revenue so that I can keep developing it full time. Perhaps these two goals/objectives are mutually exclusive.
                    design.medeek.com
                    • medeekM
                      medeek
                      The tee intersection algorithm has been revamped and is now properly cutting out top plates when walls intersect at these intersections:
                      http://design.medeek.com/resources/images/wall_su88_800.jpg
                      When a wall gets rebuilt (ie. edited, moved, opening added, or switched between modes) the tee intersection algorithm is run and any intersecting walls will be detected (any walls that are touching the wall in question and have a "tee corner" configuration at that end).
                      What this means is that if you manually move an intersecting wall and slide it along the main wall and then rebuild the main wall the top plate will automatically update with the correct cut out as shown above.
                      This update will be rolled into rev. 0.7.5.
                      design.medeek.com
                        db11
                        I think it's a big mistake to keep discounting the price of your plugins. In my view the user adoption will follow the feature/UI completeness of the plugin(s).
                        For example: the only reason that I have yet to buy the truss plugin, is that the type of truss I needed wasn't feature complete enough β€” I would have happily paid double or triple the price if all of the current features had been available for that truss at the time. (they may well be now)
                        I will buy your wall plugin once it's stable and out of beta, and given the cost of similarly deep, professionally-developed plugins (eg Garry K's Cabinet Maker), you should be looking at raising your price not lowering it.
                        Maybe have a simple version at a lower price (without advanced options) for homeowners designing a backyard shed, but IMHO you should be charging at least $50-100 for the fully featured pro version. Maybe a $99 intro bundle for all 3 β€” Wall/Truss/Foundation.
                        Then, when you add engineering specification features that you've discussed, add that version at double the price. For a pro designer, the cost will pay itself in the first project.
                        • medeekM
                          medeek
                          You are probably spot on with most of what you have said.
                          I've come to realize for me its not about the money it is simply about being able to do what I love doing, and for some reason I've really come to love programming these types of SketchUp plugins. However, the reality is that I need to somehow make enough to survive and hence the necessary "evil" of having to charge, what I consider, high prices for these plugins.
                          To be perfectly honest the Kickstarter Campaign has brought me to this point, without it and the 41 generous backers I never would have been able to devote the necessary time to even get this project off of the ground. I started programming in earnest on the actual plugin on April 5th and the initial beta was released on May 25th. I think I've been able to accomplish a fair bit of programming in this rather short span of time.
                          The plugin is in fair shape, it is mostly there but still missing a few major features and probably needs at least another two to three weeks of intense scrutiny and subsequent fixes. I am systematically going through my list, knocking things out and checking them off.
                          As you suggest uptake of the plugin is probably being hampered by the fact that it is still in a beta stage and not as fine tuned as it needs to be.
                          To keep going I somehow need to bolster sales (even temporarily), this will buy me a few more weeks of time to keep my focus on this project. With that being said I am liking the idea of some sort of bundle deal or promotion that I could possibly run for a week or two, just long enough to get me in a position so that I can continue forward.
                          Perhaps a deal where if you purchase the Wall Plugin at full price the Truss and Foundation Plugin are included. If you already own either of these two plugins then your license renewal dates for these other plugins are extended out the appropriate amounts. Also have this package deal retroactively applied to all Wall Plugin customers (within the last 60 days) so as to be fair to everyone who has purchased the plugin thus far.
                          design.medeek.com
                            db11
                            It's always a challenge to build a passion into a self-sustaining business, and not to let short-term need short-circuit longer-term thinking.
                            You've created a lot of value with these plugins and you shouldn't feel the least bit guilty about charging an appropriate price for them. Those that use SU Pro as a/the primary tool for their business will have no problem investing in plugins that increase SU's capability and/or efficiency and should be your primary target market β€” for both pricing strategy and requirements capture. Any additional revenue that you pick up from the hobby market would simply be the icing on the cake, but you shouldn't let addressing that market derail your overall focus.
                            Accordingly, I think that (eventually) having two versions β€” Hobby/Pro β€” could help with the challenge of expanding the user base while still generating sufficient funds to sustain the effort. (All the development effort goes to Pro with Hobby as just a feature-limited version of same).
                            The only caveat would be that the larger your user base, the greater the demand for user support. When you consider the truism that the customers who spend the least/know the least also tend to demand the most, you'd have to consider carefully whether directly addressing the Hobby market would be worth the potential loss of time/focus. (at this point in time)
                            I also like the idea of doing a time-limited promotion (to generate some needed near-term funds) much better than setting the long-term price too low, and then being stuck with it.
                            • medeekM
                              medeek
                              Version 0.7.5 - 05.31.2018
                              • Fixed a bug with the callout positioning method to allow for the correct placement of wall opening text.
                              • Intersecting walls now cut through the top plate of the primary walls at tee intersections.
                              • Wall cladding and sheathing materials option now added to wall creation tool.
                              • Default behavior for the Wall Mode parameter added the Walls tab of the global settings (Line or Polyline).
                              • Added DensGlassβ„’ sheathing material to the sheathing tab of the global settings.
                              • Began the addition of tooltips to every parameter within the global settings.
                              design.medeek.com
                              • medeekM
                                medeek
                                June 2018 - Medeek Wall Plugin Promotion
                                In order to help kick off the new Medeek Wall Plugin I will be running a promotion from June 1 thru June 15.
                                All orders of the Wall Plugin will also include a free two year license of the Truss Plugin ($50 value) and a free one year license of the Foundation Plugin ($25 value).
                                If you have previously purchased either of these other plugins then your serial expiration date for each plugin will be extended by the time periods given above.
                                To take advantage of this offer, once you have purchased the wall plugin, simply email me with your client ID or username and that you would like to take advantage of the June 2018 Promo.
                                For clients that have already purchased the Wall Plugin, you can also take advantage of this offer by emailing me directly as above and I will add the Truss Plugin and Foundation Plugin to your client account or extend your serials as mentioned above.
                                This offer is only good until June 15, 2018. All Medeek Wall Plugin orders made on June 16, 2018 (PST) or later will not be eligible for this time limited offer.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Looking at garage doors this morning and I have my ideas on how one should trim these out but I am wondering if the rest of community is inline with my thinking.
                                  Feel free to email me or post on the board a garage door jamb detail/section on how you would like these put together.
                                  I'm also going to add in an advanced framing menu for the garage door option wherein the user can specify the parameters for portal framing the opening, however I may not attack this one until later since there are much bigger fires to put out at the moment.
                                  design.medeek.com
                                  • Bob JamesB
                                    Bob James
                                    I've just purchased the Wall plugin, but cannot find your email address
                                    • medeekM
                                      medeek
                                      Thank-you for your purchase and you support of this endeavor.
                                      My email is nathan@medeek.com
                                      design.medeek.com
                                      • Bob JamesB
                                        Bob James
                                        Thank you.
                                        Done
                                        • Bob JamesB
                                          Bob James
                                          Version 0.7.5
                                          Made some test walls with inside corners so the walls would be drawn on the outside of the path and had two problems:
                                          I expected the gypsum to be on the inside and the sheathing to be on the outside. This is what I got with the gypsum not only not on the inside, but buried in the 2x4:
                                          And the corners are offset so they did not meet.
                                          Note also that the wood has no texture even though the Auto Assign Materials was set to "Yes".
                                          With the blizzard of inputs, I've probably set more than one thing wrong, but have no idea what.
                                          • Bob JamesB
                                            Bob James
                                            Since nearly all the homes in the California South Coast have stucco walls, can you add a flat plane cladding to which I could add the appropriate stucco material?
                                            • 11
                                            • 12
                                            • 80
                                            • 81
                                            • 10 / 81
