[Plugin][$] Profile Builder 2
@frederik said:
Cheers, Juju!
I also have Artisan and it updated without the message, so I've got Artisan 1.3.0
But the update of PB2 certainly won't work for me...Hello everyone,
The Extension Manager can only be used to updated PB2 if you have purchased PB2 from the Extension Warehouse. Otherwise, you can always download the latest version of PB2 from here:
http://profilebuilder4sketchup.com/download-profile-builder/
Note: Version 2.1.7 (just released) just contains a few minor bug-fixes.
More information can be found here:
http://profilebuilder4sketchup.com/faq/ -
Thanks, Whaat...!
Everything works fine now and I don't get the nagging window informing me that I have an outdated extension that needs to get updated... -
Whaat will we see a new major version in 2017?
Whaat please add reverse toggling (with keyboard) while creating.
I'm having an issue with Profile Builder which is very annoying. When browsing in profile folders I can't see their names in the upper row. Can I change this? Is there a solution?
your monitor setup, do you use some sort of scaling factor / %?
Thanks!You just need to stretch out the size of the window. The size of the window should be saved for next time you open it. Is this not happening for you?
Thanks for you replies! Scaling is set to 100% (I've a 2560x1440 screen). When I drag the window and try to scale it the upper folder names stay hidden...that's doesn't do anything. I'v tried a lot to solve this however...
Can you post a screenshot or a video of your window with the window width increased?
Hey Whaat...when click on the full-screen button in the window(square button) it's fully visible...and when I reopen the dialaog it's okay again (??!). Well fixed. Sorry to have you bothered!!! Feel like a noob now!
Thanks!!!
Thanks!!!
OK then! Thanks for letting me know it is working!
) Thanks again!
