    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 53.8k Views 40 Watching
    • FrederikF Offline
      Frederik
      Cheers, Juju! πŸ‘
      I also have Artisan and it updated without the message, so I've got Artisan 1.3.0
      But the update of PB2 certainly won't work for me... πŸ˜•
      Cheers
      Kim Frederik
      • W Offline
        Whaat
        @frederik said:
        Cheers, Juju! πŸ‘
        Hello everyone,
        The Extension Manager can only be used to updated PB2 if you have purchased PB2 from the Extension Warehouse. Otherwise, you can always download the latest version of PB2 from here:
        Download Profile Builder
        Profile Builder 4 (profilebuilder4sketchup.com)
        Note: Version 2.1.7 (just released) just contains a few minor bug-fixes.
        More information can be found here:
        http://profilebuilder4sketchup.com/faq/
        • FrederikF Offline
          Frederik
          Thanks, Whaat...! πŸ‘
          Everything works fine now and I don't get the nagging window informing me that I have an outdated extension that needs to get updated... πŸ˜„
          Cheers
          Kim Frederik
            rv1974
            Whaat will we see a new major version in 2017?
              rv1974
              Whaat please add reverse toggling (with keyboard) while creating.
              • pep75P Offline
                pep75
                I'm having an issue with Profile Builder which is very annoying. When browsing in profile folders I can't see their names in the upper row. Can I change this? Is there a solution?
                • jujuJ Offline
                  juju
                  your monitor setup, do you use some sort of scaling factor / %?
                  • W Offline
                    Whaat
                    You just need to stretch out the size of the window. The size of the window should be saved for next time you open it. Is this not happening for you?
                    • pep75P Offline
                      pep75
                      Thanks for you replies! Scaling is set to 100% (I've a 2560x1440 screen). When I drag the window and try to scale it the upper folder names stay hidden...that's doesn't do anything. I'v tried a lot to solve this however...😞
                      • W Offline
                        Whaat
                        Can you post a screenshot or a video of your window with the window width increased?
                        • pep75P Offline
                          pep75
                          Hey Whaat...when click on the full-screen button in the window(square button) it's fully visible...and when I reopen the dialaog it's okay again (??!). Well fixed. Sorry to have you bothered!!! Feel like a noob now! πŸ˜• Thanks!!!
                          • W Offline
                            Whaat
                            OK then! Thanks for letting me know it is working!
                            • pep75P Offline
                              pep75
                              πŸ˜„) Thanks again!
                              • 11
                              • 8 / 11
